Reverse level 6.7
Wrangler98
Maine
2021 tremor 6.7
Who has installed a reverse level? Any issues? What parts do you recommend? Pics? Rake? Alignment needed after?
Ive got 2" PMF blocks coming from santa
Dont quote me but I think 3.25 blocks come from factory
Should drop rear 1.25 from stock
I dont think alignment is necessary as youre not touching front suspension
BTW these blocks have 2 degree angle built in them so driveshaft angle isnt messed with
I’ll be interested to see how it looks! Thank you
@wildlawnboy on Insta did reverse level.
Same for me... 2” PMF blocks on the way. Once installed, I’ll post pics.
Merry Christmas to all!
Replied in the other thread. Worth it if you aren’t looking to lift your truck. I use mine for lots of things and lifted it wouldn’t be ideal. Still has a bit of rake which I like but once you toss some weight on her it’s perfectly level.
PMF 2” blocks
1.5” blocks are on the way from PMF. I will also post photos once I get them installed. It is correct that the factory blocks are 3.25”.
PMF 2” blocks
View attachment 12293View attachment 12294View attachment 12295View attachment 12296View attachment 12297
Is it possible to get a picture from underneath? Did your bumpstop tang transfer to the new blocks? Or did you get the airbag tang for them to hit?
Wasn’t sure what to order, so I called, told them what I was trying to do and they told me exactly what to order. Great people.
Here are pictures from my install. I used the 2017-2020 1.5" block kit that came with new U-bolts. From what I can tell both blocks are tapered. I noticed my PMF blocks had multiple holes on the top where the alignment pin on the leaf spring sits, so make sure you align both sides into the correct pin holes.
Thanks for the pic’s. Was the install easy?
It was so easy a cave man could do it! :) I did mine without taking the tires off and a simple socket set. It was too late to use an impact wrench, but I think you could do it within 30-45mins.
It comes with that tang on the standard block or is that the airbag tang model?
