Replacement Speaker Recommendations with Stock BO system
NorCalWingNut
Morgan Hill, CA
2020 F250 Lariat
Morning,
My rear door speakers on my 2020 Tremor seem to have finally blown out. Started with the right speaker now the left decided to join it and I cant take it anymore.
Are their any recommendations on replacement door speakers that I could swap out without having to add an amp? All the threads I've seen about speakers have been upgrades where they are adding amps and crossovers and all that jazz. I just wanted to replace them with decent speakers that will sounds good but wont require any added hardware.
I've checked out crutchfield, and it tells me which speakers will fit, which is great. But I don't want to add speakers that are under powered and waste my money.
Any real world recommendations out there?
Thanks
Take a look here for some research. https://www.mtiacoustics.net/6x9inchcomponents.html
They do a ton of work on Super Duty's--maybe look at the components they offer for the different stages as part of the upgrade builds for our trucks and then find what works for you.
Is it easy to just replace the speakers on these trucks? I mean is the BO stereo function as a system or can I replace just the door speakers and not worry about messing anything up?
Anyone know what the RMS power is to the speakers? Someday I would like to upgrade the “woofer” (yes I put quotes around woofer because well it’s something anyways) but I don’t want to lose my storage under the rear seat
I upgraded all my speakers with some infinity reference series using PnP harnesses. Really wish I could find the harness to change out the center channel. Was an ok upgrade, they're more efficient than the B&O speakers so you get a little more clarity and volume per click.
Used the soundgoodstereo harness to drop in a RF 8" sub.
Morning,
Thanks
Call crutchfield's customer service, let them help you out
These guys also have a bunch of options for speakers.
@JTredway do you happen to have a link for those harnesses or are they specific to the infinity speakers??
Forgive my ignorance!
