Replace tires help
I have a 24 XLT with 53000 on it and I want to put A/T tires on but I don't have a clue. I put an RV with it about 8000 lbs. So any help would be much appreciated .
I keep buying stock tremor wheels and tires ( takeoffs) plenty good for minor offroad and towing. My bumper pull runs about 12K lbs.
I just ordered a set of Duratrac RT's. Installation on Thursday. Breaking them in on a drive to VT soon after in some forecasted very wet weather. I'll report back on initial impressions.
I was going to buy a stock duratrax as well but they're 421 per tire and I can get 37 falkenwild peak rto1s for the same exact price. Running $1, 800 out the door
I get takeoffs new like under 1000 miles rims and tires for $13-$1500 then sell my rims for $400
Where you finding those for $421.00? That's a good deal.
Gerald's tires and brakes down here in South Carolina.
I'll get an extra $100 off basically free install almost because the manager lives on the edge of our property and I'll let him utilize about 5 acres for his bow hunting.
Originally I was going to do the at4ws but I guess they're on national Bank order and I'm about a thousand or two miles away from needing new tires
Thought about doing that at least once just to justify buying aftermarket wheels 😜
I was going back and forth between the Toyo AT3 and the BFG KO3 and decided on the BFGs. I have had good luck them (KO2s) on prior trucks. They were installed yesterday but will get tested next week with the trek to Moab!
Hope you have better luck than @Godzilla/Tremornator did.
wow they are about a 100.00 cheaper than the Toyos do you think the Toyos are that much better?
Hey I read a little more and it says that they are not recommended for full size pick ups so I am sticking to the Toyos thank for your input
FWIW I ran the Toyo RT Pros on my Raptor and it was a great daily tire.
Got it in the stock size and it feels so much better than new Duratrac tires.
Good in heavy rain too.
Wanted it again as it was a 3 ply sidewall
I support the use of the Mickey Thompson Baja Boss ATS, my 2024 has 125,000 miles with 75% of that towing on road and off. These have been by far the best for a wide range of weather conditions, including down to -40F. As I drive all over North America, I need something that can be in California one day and the Yukon the next.
I find the best test is at -20 or below with significant ice buildup on the road and a heavy sidewind, most tires loose all grip at those conditions.
Just be careful on selection as tire specifications can vary significantly based on tire size.
I just 37x12.5R18 KO3s on mine. I’ll be the first to call them out if they end up sucking, but my experience with them in every other vehicle (including an F150) has been good. Noticeably quieter than the Duras.
Time will tell.
The KO line of tires are great for 1/2 ton trucks. They just wear very quickly with the weight of these full size HD trucks. If I could ever get more than 30k miles on a set I would probably still be running those tires but they just didn’t last long.
The only downside side to the BFG KO series tires (besides mileage) was mud. They do not clear mud at all. They become slicks! But on almost any other terrain like wet, snow, gravel, loose dirt, etc……they were great to me.
OK - I have 3 weeks and a few hundred miles on the new Duratrac RT's and so far I am delighted with them. Very quiet and comfortable ride. They exhibited none of the squirrelly ride the original Duratrac's exhibited for the first 1,000 miles. I have noticed no additional harshness or stiffer ride due to the firmer sidewalls. Towing a small trailer (the motorcar in my avatar) felt like it was not even there. I will be towing my RV in a few weeks and will provide an update when pulling a 10K load.
By the way they look great - the sidewalls are more aggressive looking than the originals and with the 3 peak rating I'm anxious to try them in the snow this winter.
I just put my second set of Nitto Recon Grapps and have been very pleased with the last set which lasted 55k (and still had 8/32nd's left). I will say, they aren't the best in really wet weather and do tend to pick up small pebbles, but they are smooth, quiet, ride well, and last the full 55k+.
Fwiw, i agree with @Mad_Max. got maybe 20,000 on my duratrac RTs, they are a great improvement over the original duratracs, quieter, great in snow and ice, as good or better on the trail, wearing extremely well.
I just bought Mickey Thompson Baja Boss ATs and will say that they drive great on the road, at speeds up to 80mph (as fast as I limited myself), and look great. No off road miles yet. But they’re built like they will do very well. Also rated highly for snow and ice (which we should be getting in SW CO this year).
A little update on my MIckey Thompson tires. Just drove my Tremor from the Durango area to the Great Slave Lake (Northwest Territories, Canada) and back. Put on nearly 5k miles high speed driving (80-90mph at times). Some rain, but mostly dry highway miles. And I have to say that the tires drove great. When I had them installed, the tire guy said it took a fair amount of weight to balance them. Well, he did a great job. No wobble or discernible vibrations at any speeds. Not terribly noisy at all. And no significant wear can be seen so far. I have no off road miles yet, and no really bad weather. But winter is coming. Very happy w the tires so far. Thinking about putting a set of 37’s on my JKU.
I went with the ToYo A/T III and drove to NY and back to TX and what a difference, quieter and a mile or three better MPG . Good tip thanks
