Red Zeppelin Build
Have started to narrow down and figure out what tools and bits I want to keep in the truck for mostly helping other motorists out, and of course myself should I need to. Originally I was thinking to have as many tools as possible but figured out that doesn't make alot of sense, due to theft reasons, storing them, in addition to not having spare parts. Plus, you can't always help out in everyone's situation.
Tools:
  • 30" breaker bar with 13/16" socket (for my Tremor) and the other standard lug size sockets for other cars
  • 2/0 AWG welding cable SB350 Anderson DIY jumper cables so I can jump others without popping my hood
  • Plier assortment - Diagonal cutters, lineman, needle nose, groove-joint serrated, smooth parallel jaw, wire strippers/crimper
  • Some screwdrivers
  • 2 lb. sledge
  • Battery terminal cleaner brush
  • Tire plug kit, 4 way core tool + extra cores
  • Locking needle nose and curved jaw pliers
  • El cheapo free coupon harbor freight multimeter
  • Element fire extinguisher
Consumables:
  • Zip ties
  • Lock wire
  • Gorilla duct tape
  • JB Weld-Kwik
  • Dielectric grease
  • 3M Super 88 electrical tape
  • Splice connectors with assortment of wire
Future:
  • GearAmerica and Factor55 recovery gear
  • Factory winch or equivalent setup
@ccw
Did i somehow miss it or your build thread really doeasn’t have a single picture of your truck?🙃
Yeah it's in here. Start over from the beginning slacker ;)
13/16" socket
Aren't Ford lug nuts (and all American manufacturers) metric now? Or is this a case of the SAE and metric being essentially identical in size so it doesn't matter?
Also, while you don't list a full socket set on the list, if you want one this is a nice one to get:
Includes a breaker bar and full complement of sockets in both SAE and metric, regular and deep socket.
21mm socket is uncomfortably loose on my factory lug nuts compared to my 13/16" socket, which fits much better. I'm going to throw out the factory lug nuts soon for some one piece black ones without the chrome cap that can swell up.
Socket set was intentionally left out for now. Flat tires and jump starting are the most common thing people need help with. @ccw
Gotcha, makes sense.
If you find some black ones that will work with the factory wheels I'll also buy them! All the threads on lug nuts on the site have left me feeling like there's none that are both one-piece and will work with the factory wheels.
Check out this product for the fire extinguisher. Someone posted this somewhere and I think it’s an awesome choice for putting in a vehicle.
That's a damn great find, because it appears to have no expiration and a longer discharge time. Going to remove Amerex from my list now I guess. (y) @ccw
Same reasons I liked it. Plus the increased discharge time also
Vanair never gave me a quote yet for the PTO onboard generator. Been 2 weeks since I filled out their info.
I’ve abandoned the idea for now. Just don’t think there’s anything exactly like I want. Oh well.
Anyone else like Knipex tools?
Finally was able to touch up my powerstroke badge today. All I have left to do now for cosmetics is remove the OEM Tremor decals and apply the Signville ones, and the TVD vinyl black tailgate letters.
Keep us posted on this one! I just got my set in the mail the other day. Still waiting on the truck though. I’m assuming you just loosely tape it into place to hold it there and use the roller they provided? I’ve never applied any vinyl. Curious to hear how it goes for ya!
I'm going to be using Rapidtac wet method application, as it should let you slide it around and get it in position in case you mess up. The factory doesn't do a great job at lining them up either to be level.
Good to know. I didn’t know you could do vinyl with a wet solution. Understanding it obviously dries and sets up later.
I've decided on a Sentry CT bed cover instead of a Retrax pro MX now, because I don't want to lose bed space. Will probably pick one up in spring. The Revolver X4s was a contender but has too many issues and drawbacks reported by others.
