Red Zeppelin Build
That’s an interesting idea! Though guess that would mean you’re without it when towing?
Not true, it goes in the horizontal tube that runs the width of the truck, not the drawbar area. (McMaster plug area)
Getting better... $300 less on this site for the 18" version:
Would probably have to open up the center for the cable mount and then add a couple studs so that it could be physically mounted to the spare. There isn't much to this... still outrageously priced!
Some have made their own version:
Ohh I see now. That’s very tempting.
New product idea :D with Kaizen foam and a Noco battery jumper.
It is tempting, but I highly doubt my dual batteries will go dead. If anything the battery connector terminals would probably loosen up over time.
Agreed. Also have dual batteries and think it's incredibly unlikely, but the consequences could be pretty severe if I'm out in the middle of nowhere when they happen to run dead.
Unfortunately, my black 'B' door pillars are pretty swirled up now. Not sure why they buffed the entire truck, should I just leave it be or easy to DIY fix?
I might see about getting them vinyl wrapped I guess..
Can you go back to the shop and ask them to fix it? Seems pretty crazy to have to accept that.
I was originally thinking: "Black A-Pillars, that's a new one..." then I saw your edit... :p
The more hands that touch this truck the worse it gets I've noticed. Doubt it's worth my time at this point. Thing has taken too long already to get to this point.
I have to redo my plastidip powerstroke badge on passenger side since their buffing wheel caught the top of it. Hope I can just spray touch it up since peeling it completely is a royal pain and took more than 2 hours with a toothpick. (Had experience on driver side when the plastidip can decided to spray out a mess at one time)
Nope, this is for after installing the Jimmi Jammer and, in the process, removing the keyhole and manual door lock. The key hole is apparently super easy to break into.
Once the key hole is gone, the only way to get into the truck when the battery is dead is give power to the truck so the proximity sensor works.
The door handle covers are easy to take off. What if you left the keyhole, and ability to use a key, but bought a handle cover for the driver rear door and just put it on over the driver’s handle keyhole? Stealth but low tech and easy
Well now that's an interesting proposal. How easy are we talking? No tools? Basic flat-head screwdriver?
Hands only. Search “precision retrofits’ on YouTube. They do repaint jobs of stuff, handles included. You can take the covers off very easily with just your hands
I’m willing to bet a cover with no keyhole would fit just fine over this
Side note, they showed how to take off the “platinum” tailgate appliqué. I’m sending mine to them to have it painted to color match the truck, along with my handles. Need to buy a spare one and do this to my own truck would look great with no keyhole
That would also make it easy for a thief again at the same time lol.
Sure, if they knew there was a keyhole underneath or how to take them off. I think that’s giving a thief way too much credit. They are looking for the easy score. Not a truck without a keyhole
I’m headed down this same path, too. If they’re determined enough they’ll get in no matter what. But throw them off with a blank door handle, would they risk trying to get the handle apart to maybe find nothing?
