Project “Truck Norris” 2022 F450 Platinum short bed and super single conversion
A little update on the build:
I'm testing out a new prototype Carli Progressive "Heavy Duty" front springs with 5.5" lift. The prior Carli progressive springs sagged due to my heavy Bodyguard front bumper and Warn 16.5ti winch. I believe this added about 450lbs to the front of the truck and the springs lasted about 8,000 miles and 16 months on the truck. New front springs will be installed tomorrow. I am still open to doing a coilover conversion but if this works well I might be done. I LOVE the new valving on the 3.0 dominator shocks that my local suspension shop RLT Suspension did. I needed a custom valve job to match my build and it was money well spent.
On my rear coil conversion I'm upgrading from the 4800lb Tremor 7.3L springs to the 5200lb Tremor Diesel springs. I needed just a tiny bit more spring rate for around town. This changes from a 410lb per inch to 430lb per inch spring rate. I have my Carli long travel airbags for when I tow, but the rest of the time I want the plush ride.
DBL Design has a new high clearance rear swaybar coming out that should go on my truck this week. It's similar to stock rate but just a slightly different design by the end links and rear axle pumpkin. I had some instances where my swaybar and rear drag link would slightly "kiss" under heavy compression. I think the swaybar change will address this issue, but just in case I'm also changing the rear drag link from a 2.5" DOM tubing to 2.0" DOM and thicker sidewall. That 1/4" of clearance should solve the issue and the new swaybar gives me more clearance by the end links. Also, the new rear. drag link might give me enough space to squeeze in some rear bypass shocks if budget allows.
Front fenders, bed and rear fenders are being painted this week. Making sure the paint is 100% with no rock chips so it can get the STEK PPF installed at the end of February. I have all the parts getting an extra bake in the paint booth just in case, since my timeline for PPF is tight. I have a few more little things I might do while the bed is taken off for the PPF install, but we will wait and see how much money and time we have. I should have some solid pictures to post this weekend or next when I fly to Dallas and drive it home.
This isn't a Tremor! 🤣
I realized all of the pictures I uploaded last night are with the 365/80R20 43.0" tires. Here are are few pictures with the 335/80R20 41.4" tires. I think it definitely looked more aggressive with the larger tires, but the "smaller 41.4" tires have zero rubbing under off road conditions and are about 29lbs lighter per tire, so stopping and turning is much improved with the lower rotational mass.
I prefer the 41 look.
Oh, and next time you're in Vegas have the decency to inform me so I can check out this thing you call a truck while doing shots of bourbon 🤪
Haha will do!
Man, this thing will go where Tremors can't ...
Would love to see pics when you have the new swaybar installed. Starting to create a wish list for my new rig and will consider a swaybar again.
I will try and take a comparison shot of the new swaybar design vs stock ford swaybar.
You trying to sway us
Either way, we'll be swayed.
Intro and backstory on the build:
I had the truck at Les Schwab tire shop today getting the drag link tie rod end replaced and the mechanic called it "Truck Norris" which I thought was cool, so that is the title of my build thread :LOL:
I bought my first Ford truck during the Covid lockdowns, a 2020 Ford Raptor, lead foot gray with the blue Recaro seats. I owned it for about a year and really enjoyed it but wanted to be able to tow more. I saw a couple videos on YouTube of super single diesel trucks and reached out to a few companies for quotes. Fast forward two years later and here we are. I probably should have started this build thread a while ago but hopefully this will be good info for anyone else that is looking at doing something similar.
What are my goals? I wanted something that could tow a large toy hauler, offroad capability to get to campsite or recover my RZR at Moab, daily driver comfort and a little different than every other truck build I see around town. I also wanted to be able to park in my garage, so a long bed was ruled out. I have never owned a diesel truck but knew that was the route I should go because I wanted to tow a heavy toy hauler. I also was worried about being able to change a flat tire and came up with the idea of a bed mounted davit crane. I will expand more on the crane in another post.
I reached out to DBL Design in Dallas, TX December 2020 for a quote to do a build and that started me down a deep rabbit hole trying to figure out what I wanted and if I could actually make this happen.
About four months later I sold my Ford Raptor and ordered a 2022 F450 Platinum. I put down a deposit with DBL and started ordering parts for the build. Remember at this time during 2021 everything was out of stock or delayed months.
When I ordered my truck I checked all the boxes- (antimatter blue, F450 Platinum pickup truck with adaptive steering, PTO, Vinyl floors, Rapid supplemental cabin heater, engine block heater, multi contour seats and panoramic sunroof). I was one of the lucky ones who got Adaptive Steering and Multi Contour Seats in 2022! It helps that I purchased through Grand Prairie Ford and my Sales Rep Dan Munro is one of the top sales reps for Ford in the US. In January 2022 my truck arrived and I flew to Dallas to pick it up. I literally drove it 20 miles from the airport to the dealership and then dropped it off at DBL Design.
Daniel @ DBL Design told me had done several short bed conversions and we agreed that was the direction I wanted to go. I had a budget but as these builds go, I went way, way over. I dropped my truck off January 5th and it left their shop on Halloween. During the build process I was offered a “feature vehicle” spot at SEMA 2022 which was only 2 days after my truck first drove on the freeway) and jumped at the opportunity. Bodyguard Bumpers and DBL Design sponsored me and it was fun and stressful experience. I drove 20 hours from Dallas to Vegas on a FRESH build. Only 30 minutes or so of driving it to the alignment shop and for dinner the night before we left.
I will try to give a breakdown on the upgrades and reasoning. As with any build it’s always a work in progress…..
During the past year I changed headlights, fog lights, wheel powder coat color and brand, tires, springs, shocks and a few other things along the way searching for perfection. So some of the pictures might not exactly match the list below, depending on when they were taken.
I think this list is pretty accurate list of the current modifications:
Mechanical:
Full Screen CarPlay and all module firmware upgraded
Optima Red Top Batteries - thanks to Optima for the free batteries at SEMA 2022!
Relocated DEF tank to spare tire area
Factory long bed 48 gallon Diesel tank
BEM locking fuel cap - Diesel and DEF
MBRP Black 4" double wall exhaust tip
Oasis XD4000 12V DC Air Compressor
Viair 91022 2.0 Gallon Tank
Pacbrake Wireless Air Spring Controls
ARB Hose Coupling
Whits End - ARB Fitting Air Coupler Pacifier Black Delrin
Steel braided airbag lines - made by local hydraulic service
Drivetrain:
DBL Design Pro80 Front Steer Axle upgrade
Auburn Gear 6.17 re-gear on front and rear axle
Auburn Gear Front Electronic Locker
Rear Factory Limited Slip
Warn Super Duty Front Hubs
Spicer Dana 80 Front Diff cover
Ford Performance Rear Aluminum Diff Cover - came stock on the F450
Brakes:
DBL Design F450/550 performance brake kit - upgraded 16” drilled & slotted rotors front and rear with upgraded brake pads
Carli Suspension steel braided brake lines front - for 5.5” lift
Custom rear steel braided brake lines
Suspension:
DBL Design 4 link rear coil conversion with Ballistic Joints on all links
Carli Suspension progressive front springs - for 5.5” lift
Ford OEM F250 7.3 Tremor front springs used in rear for coil conversion
Cari Long Travel Airbags
Carli Torsen Front Swaybar
DBL Design Rear Swaybar
Carli Fabricated Radius Arms (v2 w/ more castor adjustment)
Carli Dominator 3.0 shocks, cerakote tungsten grey - previously had Carli 2.5 pintop shocks - 5.5” lift
PMF Dual Steering Stabilizer w/ Fox 2.0 stabilizers, cerakote tungsten gray
Dual PRP limit straps on each side of rear axle
Single Front Carli limit strap on Fabricated Radius Arms
PMF Drag link
Wheels:
DBL Design 20” MRAP double bead lock wheels. These are military takeoffs with a custom designed billet aluminum center that we designed to fit the 10 lug ford hubs. Each wheel weighs 75lbs and the G275 335/80R20 tires weigh 133lbs, the Goodyear G275 365/80R20 tires weigh 162lbs!
Gorilla Black Flat seat lug nuts
Goodyear G275 335/80R20 Military tires, 41.4” inches - yes I know my name says F450 on 44’s and these are not 44’s. Previously had G275 365/80/R20 tires on the truck for the first year and the SEMA photos. These are technically 43.0’s but I didn’t realize that until after I created my account on here.
Centramatic dynamic wheel balancers - special part with more balance media for super single tires. I believe it has 12oz of balance media vs standard F450 balancer they sell with only 6oz of balance media.
Mac’s Custom Tie Down Y Strap - for the bed mounted full size spare
DBL Design Rear Dually spacer
Exterior:
DBL Designs Gen4 front fiberglass fenders w/ fender liners
DBL Designs Gen4 rear fiberglass fenders w/ fender liners
BodyGuard A2 front bumper w/ Warn 16.5ti winch
BodyGuard A2 rear bumper w/ Warn 16.5ti winch
DBL Design Class 6 rear receiver with winch mount
50 caliber bullet antenna
Full chrome delete - most items painted satin black or antimatter blue
Lariat Black appearance package front grill and Ford Emblem
MasterPull SUPERLINE XD WINCH LINE | 7/16" - 85ft - on front and rear winches
Warn Argent Gray Fairlead on front and rear winches
B&W Tow & Stow Adjustable Trailer Hitch 3" Receiver, 7.5" Drop, 21,000 GTW
Amp Power step 2” drop extensions
Dual Monster Hooks on rear bumper
Dual Warn D rings on the front bumper - argent gray color to match winch fairlead
Infinite Rule locks for the Warn D rings, Monster hooks, hitch pin and B&W Stow and go kit
Bull Ring Ford Flush Fit Tie Down Anchors
Builtright Industries Bedside Rack
BAK Revolver X4S Black roll up Tonneau Cover
Interior:
TheOCDPlug 12" screen protector
Domestic Center Console Fridge
xpel Ceramic window tint - 35% on all windows and sunroof, 70% on front windshield
TST 770 TPMS Sensor kit w/ 5 flow through sensors
Lighting:
Morimoto Amber DRL LED headlights. I originally swapped the Chrome LED’s for Black LEDs and then later on swapped the OEM Black LED lights for the Morimoto’s.
Rigid 20” Spot midnight LED in the front bull bar
Right D Series Diffused “work light” in the front bumper outside opening
Baja Designs Amber Squadron SAE v2 Fog Lights - Wired to factory fog light switch. I had the Rigid’s D Series Pro SAE Fog but I prefer the beam pattern on the Baja Designs and I think they match the LP4’s better.
Baja Designs LP4 Amber ditch lights
SDHQ A-Pillar ditch light brackets
Baja Designs LP4 Reflector covers
Right D Series Diffused flush mount “work light” in the rear bumper
Morimoto smoked side marker lights - not installed
Misc:
OZ Lifting Products CompOZite Elite Carbon Fiber Davit Crane — 1200-Lb. Capacity, crane weighs 40lbs
OZ Lifting Products Pedestal Base mounted to truck bed w/ supporting steel subframe below
Masterpull SUPERLINE WINCH LINE | 1/4"x 25 ft w/ puck (for Davit Crane)
The Grabber - Winch Line Attachment - 1/4" (for Davit Crane)
Ford Upfitter decals from Ebay
Pro Eagle 3 Ton Jack w/ mount and cover
HULKMAN Alpha100 Jump Starter w/ Case
Milwaukee M18 Fuel high torque impact gun w/ sockets
The day I picked it up from Grand Prairie Ford:
View attachment 131537View attachment 131538View attachment 131539
SEMA 2022 "feature vehicle" outside of the west hall
View attachment 131532View attachment 131531View attachment 131540View attachment 131541
Post SEMA 2022 Photoshoot in the Las Vegas Desert w/ Bodyguard Bumpers
View attachment 131534View attachment 131535View attachment 131533View attachment 131536
Looked into getting my hands on a Oasis XD4000, how does yours hold up, and where do you have it located? Thanks for any info, beautiful truck!
I mounted the Oasis XD4000 in the spare tire area and then ran a rubber hose for the air filter up into the bed. I have a tonneau cover and wanted to make sure the air filter was out dry. So far it's worked great. I don't love the on/off toggle switch that is on the top of the compressor because it's very hard to reach but now it's ran to one of the upfitter switches. I have a 2.5 gallon tank with a pressure switch that turns off at 120psi. Originally it would just turn off automatically when the tank was full, but I had a mystery leak in my airbag system so my compressor ran randomly when the tank pressure got low from my slow air leak. Obviously not great, so we changed out all the pressfit and rubber air lines to braided stainless steel and now there is no leaks and I only turn the compressor on when I need more than what the 2.5gallon tank can hold, like airing up my 42" tires. Most of the time I don't turn the compressor on to adjust the airbags.
I recently had the bed off the truck and decided to change the oil on the compressor. I think you can do it with the bed attached but my truck has a bunch of stuff in the way with my rear coil conversion and airbags. So depending on how often you run it you will need to change the oil.
If you are only using it to air up tires or maybe run an occasional air tool it works great. I will try and take some pictures of the install if you are interested.
@BroncOh
I installed your new tank warden today and I really enjoyed the design over the BEM fuel locks. The BEM has worked flawlessly but I recently had a tendon replaced in my right wrist, so spinning the key is the exact thing I cannot do right now. Side note, if anyone wants to buy my used BEM setup PM me. I felt like the extra cost was worth it, I also love the fuel cap holder. The packaging was very nice too! I can tell you pay attention to all the details.
Before:
After:
@BroncOh
Before:
After:
Thank you again! I hope your wrist makes a full recovery from the tendon replacement.
@BroncOh
Before:
After:
Dude, where have you been? It's been like, months, like, whatever if you've moved on 🤪
wow.. just saw this post and yes I haven’t done any updates in a long time!
I sold my old wheel/tire combo and I just got my new setup dialed in this week.
Wheels - DBL Design one-piece “gear” forged super single wheels, 8,400lb load rating, 62lbs. These are the first machine finish wheels I have ever owned. I usually do a gray or bronze color powder coating but right now I’m really enjoying the new look.
Tires - Michelin MPT XZL Military tires in a 365/80R20 43.4” size. I’m rounding up to 44” 😎 Yes I was running the 335 Goodyear tires for a while which were 42’s and I should of changed my username but I didn't.
Last year Michelin only sold these for gov contracts. They have a very tough sidewall from what I have heard, much stronger than the Goodyear tires. These just became available for civilian purchases and I wanted to try them out. Previously I ran the Goodyear 365 and 335 sizes. I ran both the 335 and 365 Michelins and the 365’s are heavy, but less road noise and I think they fill out the wheel wells nicely! Overall the new setup with 44’s is about 80lbs lighter rotating mass than the previous setup because I switched from bead lock wheels to one piece and also no rear spacer. These new wheels are reversible so rear spacer is not needed.
I also installed a PPEI +60hp PCM tune and TCM tune. The TCM tune was amazing! I’m running new 6.17 gears and everything is happy and running smooth right now. Before it was not great and sometimes a little “clunky” with the tcm set for 4.88 gears (max setting) and running a 6.17 gear.
I also removed the Carli long travel airbags. For whatever reason, these have been a huge problem with my rear coil setup and dominator 3.0 shocks. With the bags removed my truck rides like a big Raptor. No more rear clunk! I don’t tow heavy, just an enclosed aluminum trailer with toys.
If you have another airbag suspension idea please let me know. I am running rear coil springs, so it has to mount on the axle tube, and I don't have much space because I have an axle truss. Maybe I will upgrade the spring one more level and not do airbags at all?
Here are some pictures of the new setup:
New setup looks killer!
I think we may look at doing Full Travel Bags in the rear.
I have a friend who uses their product on his RAM and is very happy. I looked online and didn't see a Super Duty-specific kit. If we can piece together a kit or they need someone to do some prototype testing, let me know.
They do offer a Super Duty kit and a DRW version as well. We'd just need to go over the specifics with them about your exact setup to make sure it had the correct parts.
Goodbye dual steering stabilizer, hello PSC DDS hydraulic assist steering!
I spent the last two weeks on a side quest. About six months ago, PSC released their DDS hydraulic assist steering stabilizer kit for the super duty and immediately I wanted it. I called and they said it was not compatible with adaptive steering :( I was in the Dallas area the past few weeks and decided to drive to their offices and have them check out my truck in person. Apparently, it could work with adaptive steering, they just hadn't tried it.
This kit is made for the Cabin Chassis truck, not the pickup truck version of the F450.
I am also running DBL's Pro 80 front axle, Carli Panhard bar, and a custom 2.25" tie rod bar. We started modifying the Dana 60 bracket, which was way off, and later found out they had a prototype Dana 80 bracket that was close and only needed a little modification to make it work. I pieced together a custom clamp at the last minute using some 2.25" DOM tubing, which will need to be remade with a thicker wall and larger bolts, but it works for now.
I believe the new kit could be used on a F250/F350 but they would just need to de-stroke the cyclinder a little bit because they turn at lower angle. Right now my truck shows on the offroad dash screen 44 degrees of turning to the left and 45 degrees to the right. I want to say the F250/350 is 37 or 38 degrees. Maybe someone can chime in with numbers?
On the freeway there is zero steering wheel movement. I can drive the truck one handed now! Before you really needed to hold on with both hands as the big tires sometimes follows the semi truck ruts in the road. Also, I wasn't able to turn the steering wheel past 18 degrees when the truck was on pavement and stationary. Now I can easily turn the steering wheel from lock to lock!
Here are a few pictures we took. I was trying to flex it out and also turn it full lock to lock to check clearances.
