- OP 🔹
- #61
Pressure is great.Beautiful - love the shower tube.
How's the pressure and can you explain the build of it?
Thanks for the write-up!Pressure is great.
I followed this guide: https://www.rei.com/blog/camp/diy-car-top-solar-camp-shower
TLDR:
I got a 10ft long 4" Black abs pipe from Home Depot and cut it to almost the size of my truck bed. I left enough room for the hose and attachment. You will need two 4" abs pipe caps, 4 Y, cap for Y, abs cement. This is a pressurized system that requires a Schrader valve to add air pressure with hand pump or in my case a Dewalt Digital Tire Inflator. You will need to drill holes for the Schrader valve and the hose bibb on one cap before gluing to the main pipe. I pump it up to 30 PSI after filling with water and closing the tank cap on the ABS Y. It holds about 5 gallons of water.
Is this something that would be easy to remove if need to or is it a royal pain once on the truck?I added a Softopper to my truck. I love it. Works for all my needs. I wanted the ability to have a covered space for my dogs, still haul big items, and maybe camp in it as well.
View attachment 146366View attachment 146367
Super easy! It folds down to the cab and sits on the bed rail. I have access to my full bed and can see out my rear windows. It takes about a minute or less to fold it down. That was one of the main reasons I got the Softopper. I still want access to haul big items. I can also remove it completely out of the bed in 2 min. The rails for it sit on top of my truck bed rails that are clamped up similar to the backflip or other covers. That would take longer to remove, but there really is no need to remove those.Is this something that would be easy to remove if need to or is it a royal pain once on the truck?
Do you still have the starlink mounted in the bed of the truck? How is that working out? How fast do you think you can drive with it out there? I'm trying to decide if there is an easy way to use mine while in motion. I have the Gen 2 and I don't really want to cut it up and put it in a low profile box because I use it in several applications where I already have mounts similar to yours.Installed my Starlink roof mount to my Built Right industries bedside rack system.
View attachment 111143View attachment 111144View attachment 111145
Yeah I do, but I also mount it to my truck camper. I don’t think the motor can handle serious off roading, but moving on the street is fine. I usually use it for camping or extended stays. I haven’t gone freeway speeds with it. One thing I will change is drill a hole in the pipe to make it more secure. I feel like the push button could pop if I hit a pothole or dip in the road.Do you still have the starlink mounted in the bed of the truck? How is that working out? How fast do you think you can drive with it out there? I'm trying to decide if there is an easy way to use mine while in motion. I have the Gen 2 and I don't really want to cut it up and put it in a low profile box because I use it in several applications where I already have mounts similar to yours.
Learned the hard way when picking up the camper that I need to raise it up in my bed. The camper took off a part of my spray in bed liner under the rear window and made some minor scratches on the roof.
View attachment 147461View attachment 147462
So I used some left over 4x4s and cut them to bed length. Lifts up the camper nice and I can also keep my Softtopper rails on the truck bed rails now.
I will probably add in some more side supports to help the camper from shifting on rough roads. I am going to see how this works out before making something more solid. I want the ability to remove them easily to still use my truck bed when the camper is off.
