Hey everyone,
Well, it took longer than I wanted, but the cowl water diverter is finally done and up on the site. Thanks for hanging in there while I kept tweaking it. A lot of what ended up in the final version came from this thread.
Quick rundown on where it landed:
- It bolts in using the factory mounting points. No hooks and no drilling, and it's stainless hardware with a captured lock nut, so it's not going anywhere.
- It's wide enough to catch all of the drainage coming off the cowl, and the floor slopes to the drain so water doesn't sit in it.
- A filter tray screws in to catch leaves and the bigger debris before they reach the hose. Once it’s in, you shouldn’t ever need to touch it.
- It's made from carbon-fiber-reinforced acrylonitrile styrene acrylate, so heat isn't a worry.
- Comes with 18" of 5/8" silicone hose and a clamp.
- Passenger side, 2023+.
It's $54 and here's the link:
2023+ Ford Super Duty Cowl Water Diverter
Your fuse box is sitting in the drain path.On the 2023+ Super Duty, the cowl channels rainwater right down onto the underhood fuse box. All it takes is one cover tab that doesn’t seat fully, and water gets into the fuse box. Then you’re chasing electrical gremlins, or paying for a whole new fuse...
opentrailcreations.com
While I'm here, a few other things went up recently in case you missed them:
- Console pocket that sits next to the phone mount: https://opentrailcreations.com/products/2023-ford-super-duty-console-pocket-for-phone-mounts
- GearVault for the F-150, for those of you with one in the driveway too: https://opentrailcreations.com/products/gearvault-upper-glove-box-organizer-2023-ford-f150
- GM upfitter harness for the Silverado/Sierra crowd: https://opentrailcreations.com/prod...tter-switch-harness-engine-bay-relocation-9l7
One heads-up: the day job has me traveling for the next couple of weeks, so orders may take a little longer to go out. Everything will still ship, just give me a bit of grace.
Thanks again, everyone.
– Richard
