One-way preset pressure schrader valve?
Houston, Texas
'22 F350 Platinum Tremor 6.7 AMB/Black
'24 Toyota Land Cruiser FE | '22 Shelby GT500 Heritage Edition CFTP POTS | '23 BMW M4 Comp. xDrive
I'm not sure what to call what I'm looking for, or if such a thing even exists. Here's what I'm looking for:
I'd like to run a permanent line from my air tank to my Waterport Weekender pressurized 8 gal. water tank. The tank is pressurized to 30 psi max. When/if the pressure drops, I just use a mini bike pump to pressurize to 30 psi. Is there a one-way check valve that I can install inline between my air tank and the water tank to maintain 30 psi? Thanks in advance for your help!
I'd just get a typical tank regulator and set the pressure to 30psi. Something like this, although I'm sure you can find plenty of options out there:
If the Schrader valve isn't replaceable you can plumb in a locking adapter like this:
@Modman Thanks...that gives me some great ideas to get started!
