Oil change
IF Amzoil was really as good as they say, we all would already be using it. :)
"F" AMSOIL !!! and their WAY WAY WAY overpriced oil for what you are getting. As a retail dealer ( for close to almost 30 years ) Someone has to pay for their multi-level marketing and that is 100% reflected in their price of their products. Amsoil doesn't want to pay to be on any list for the 100% sole reason it is ALL about the $ with them. PERIOD !!!
Gotta love the "cheerleaders" .. oh I run Amsoil, my engine is going to last forever. etcetc. News flash: if your engine is going to last 500,000 mi on Amsoil, its going to last 500,000 on Rotella or many others on "the list" for that matter. ...for half the price;)
PS: Neither Amsoil ( even the top of the line SS ) or Mobil is 100% Group IV of V ( so called "true synthetic" ) Many are incorporating Group III or GTL.
Yeah, you are correct, the so called "true synthetic".....aka, "full synthetic" is NOT 100% synthetic oil. The last time I checked was a few years ago, and at that time I was only able to find one source for 100 PERCENT synthetic oil.....a company in Canada, and it was very expensive.
Ford doesn't make companies to pay to be on the list. I want to say at the beginning Ford tested oils and found plenty to not be able to hold the wear to a point Ford felt it was acceptable. Ford then developed their own "spec", which isn't uncommon in any way. Ford just made oil companies provide more protection hence if you want PSD owners to run your oil just make it meet these specs. Amzoil just refuses to actual put the Ford spec on their bottle.
Do you have the Ford letter about the oil spec?
BTW ever wonder why Amzoil has changed their position on extended oil change intervals???
It's not cause the big 3 changed the OE oil change intervals.
whats the reason behind this, or link to article ?
It's in all their own product pages as compared to years ago where they advertised the extended intervals.
Previously: To the point that their product pages said to pull out 1 qt, send in a sample, add 1 qt to top off, and await the results. By adding 1qt of fresh oil at every oil sample "interval" all you are doing is sweeting the pot. Yes, you still got to drive the XXXX interval, but you did just "top off" with fresh oil.
In the end their position has changed :
Signature Series Max-Duty Synthetic Diesel Oil
Diesel Engine Service Life
  • Heavy-Duty On-/Off-Road: Three times (3X) OEM1 recommendation, not to exceed 60,000 miles/600 hours or one year, whichever comes first.
  • Turbodiesel Pickup: Two times (2X) OEM 1 recommendation, not to exceed 25,000 miles or one year, whichever comes first.
  • Competition Service Life: Provides lasting protection for multiple events. Use oil analysis to determine appropriate drain intervals.
Gasoline Engine Service Life
  • Two times (2X) OEM1 recommendation, not to exceed 15,000 miles or one year, whichever comes first.
Heavy-Duty Synthetic Diesel Oil
  • Recommended for the drain intervals stated by the original equipment manufacturer (OEM).
1 Refer to your owner’s manual for OEM drain interval recommendations and guidelines for severe and normal service.
Since the last time in 2020 :
Note: Extended drain intervals are not recommended for performance-modified engines, when using biofuels containing more than 10 percent ethanol or 15 percent biodiesel (B15) or for 2007-2009 Caterpillar C13 and C15 on-highway engines. Extend drain intervals beyond OEM recommendations in these instances only with oil analysis. Note: 2007-2010 Dodge, Ford and GM turbodiesel pickups are also not recommended for extended drain intervals when using Signature Series Max-Duty 5W-30 Synthetic Diesel Oil (DHD).
you know what's crazy, i spoke with Blackstone Labs and they said oil expiring on time (6mo, 1yr, 2yr etc) really isn't a thing anymore. With all the stabilizers and such it won't go acidic and as long as your aren't leaking fuel or antifreeze you're good to go.
Oh boy...there goes the neighborhood. Just wait till that hits mainstream.
