There is a thing referred to as "infant mortality rate" that is somewhat common terminology in all manufacturing. This simply means that if there is going to be a catastrophic failure (IE engine grenades) that it will likely happen with very low hours on it.
I spent several years as an automotive technician and several more working in MRO and ending my career in Industrial Automation. I can safely say that "lubrication related failures" outside of issues caused by NOT changing oil are so rare that if what you are using is slippery and clean (and close to proper specifications), you will likely get by with it for decades.
I will likely use either Rotella synthetic or Mobil 1, and will likely lean more towards Rotella due to the ease of finding it if needed.
Interesting factoid on synthetic oils, only Amsoil and Mobil 1 are "true synthetics", meaning they are built from non petroleum sources. All of the rest are modified petroleum based lubricants to remove the odd sized molecules.
