- Dec 21, 2021
- 1,662
- 3,656
- 2022 7.3L F250
- Assorted vintage trucks, motorcycles, and bicycles.
Looks like they did their etch bath w the straps in place.Not sure why the tank came out like that.
Bingo. Maybe they strapped it down so it wouldn’t float.Looks like they did their etch bath w the straps in place.
What brand and size is the tank?Hard coat black looks good! Waiting for longer u-bolts to come in then i'll get it mounted.
Not sure why the tank came out like that. Wife picked it up for me. I'm just gonna roll with it. Its alum anyway.
If I were trying to dip something like that into any type of bath where it might float, I'd thread a sacrificial rod into the opening to seal it and assist in pinning it down.Bingo. Maybe they strapped it down so it wouldn’t float.
good point. I asked them to anodize the inside too but the way the holes are drilled, there is a flashing of metal (threaded, interestingly enough) that protrudes into the tank about 1/8". B/c of that they advised against since they wouldnt be able to get all the liquids out.Looks like they did their etch bath w the straps in place.
Airmaxxx 3 gallon aluminum - has 3/8 and 1/4" connections 200psi rated.What brand and size is the tank?
No reason you couldn't flush it w alcohol or thinner and then use compressed air to dry the inside. The remainder around the inlets would just evaporate.good point. I asked them to anodize the inside too but the way the holes are drilled, there is a flashing of metal (threaded, interestingly enough) that protrudes into the tank about 1/8". B/c of that they advised against since they wouldnt be able to get all the liquids out.
It would have been one big float since they plugged it
Kinda sucks though b/c ill never be able to drain ALL of whatever liquid is inside it. oh well.
However, I did find this tank shortly after thats prime and a touch cheaper granted it says it only has 1/4" connections. Its 200psi rated too.
I've changed course a little. At this point in time i'm only going to run one AZ. I have a KY trip in April that has a decent to-do list and a second compressor is not high on that list.You're still using mounting two AZ's, yes?
I hope so.I'm sure this will come out great with the amount of effort you're putting into this project.
Use the air compressor to stoke the fire too! Always used a Coleman inflator as a kid, D batteries not included.I need a remote air filter box for my air compressor for my trip in April. whipped this guy up to mount on DS rear bed post.
It'll go where my tailguard normally goes on the driver side, using the same hole too. I'll 3d print an elbow to thread into through the TailGuard hole (going to use screw threads not NPT so i can get good thread engagement but allow me to cinch it down). Easy access with the taillight out so just need to confirm mount holes are aligned. Elbow will face down allowing me to route the hose up the bed post and band clamp it on. The add'l hole on this will allow for a bolt to mount in the center hole on the bed post. help carry some of the weight.
I'll print an extra elbow and take on my trip JIC i happen to schwack this thing and shear the first one. I'm in charge of getting the nightly campfire goingtherefore i'll be the one luggin wood. decent chance a schwacking could take place.
I'm thinking ASA-CF just in case this becomes temporarily permanent.
What filter did i make it for? the spare one I had for my lawn mower![]()
not a bad idea but not knowing where i'll be setup relative to the fire vs my hose length, i'll just use these portable guysUse the air compressor to stoke the fire too! Always used a Coleman inflator as a kid, D batteries not included.
test prints came out and fit fantastic. Having a scan of the bed post came in clutch.I need a remote air filter box for my air compressor for my trip in April. whipped this guy up to mount on DS rear bed post.
