- Staff 🛡️
- #1
- Jun 25, 2021
- 10,998
- 20,648
- 22MY F250 Star White Lariat Tremor
- 22MY Winnebago Voyage 2831RB
Guessing improper loading but it's difficult to tell:
This, for sure...so they at least strapped it good and likely hit the strap saying that isn't going anywhere.
Agreed with this analysis. At a minimum the lower parts of the load still seems to be against the front of the trailer once it was all over (I.e. didn’t shift backwards during sway and spin), and they were hanging quite a ways over the end of the trailer.The way that it almost stops swaying or spinning once he's facing the wrong way seems to say its loaded wrong. Once the trailer got in front it was all happy again.
At the end of the video, granted a lot happened before that, the load on the trailer seems very back heavy. Buy it does seem like every stayed on the trailer other then that random palet, so they at least strapped it good and likely hit the strap saying that isn't going anywhere.
Might need to leave their underwear behind after that, too!Hopefully the driver can move on and leave this all behind him.
While hard to see, there was a red flag.That’s pretty ridiculous. Traveling at highway speeds and no red flag either. He deserved to trash his truck and got incredibly lucky to be honest. You can’t fix stupid.
I've always been told hammer the throttle and hit the manual trailer breaks.Am I wrong thinking that braking makes the sway worse? For some reason I’m under the impression that I should let the truck slow itself down on its own, but I’m not sure. Obviously proper loading is key, but things happen, and if this ever happens, I want to make sure I respond correctly.
No one said sledge, sounds like user error.Instructions unclear, sledge hammer jammed between floormat and accelerator.
Nope, you're not wrong. Braking (especially hard/panic braking) shifts load to the front of the vehicle, reduces the tire contact patch at rear of the truck, and makes it easier for the trailer to have its way with it... Classic trail brake oversteer.Am I wrong thinking that braking makes the sway worse?
Still can’t spot it but I will take your word for it and blame the crappy video quality.While hard to see, there was a red flag.
Can confirm the flag. It was all of a few flickering pixels lol, but it's there.Still can’t spot it but I will take your word for it and blame the crappy video quality.
Actually, found an even better spot to see it near the end of the video when things have slowed down and the filming vehicle is closer. You can see the orange/red from the flag in this screenshot at 18s (it's even more clear in the video as you can see it flapping).Still can’t spot it but I will take your word for it and blame the crappy video quality.
Also worth noting the importance of a drop hitch. Raising the tongue of the trailer too high makes sway even worse, and may have caused his load to shift further backwards at speed.
