Need some help after 5 inch BDS Radius Arm lift.
While the all-knowing Alpoba may feel it appropriate to admonish
Don’t twist and turn my messaging, because that is what you are doing. There was no “ admonishing” on my part.
My point was that these complex suspension and steering /wandering issues don’t get resolved on the forum threads. And yes, i’ve been following these suspension problem threads on the forum for good 3-4 years now, every single one of them as they pop up. And no, NONE were ever solved by a simple advice on +/-caster, caster shims and/or steering dampeners.
The best thing OP can do is have the issue diagnosed by a professional suspension shop, who will actually run the diagnostic looking at the truck in front of them; take it out for a test drive and rule out potential issues one by one by doing proper testing.
Just want to clarify that I don't and will never take anything personal when it comes to asking questions for help. I know those type of questions get old. I do appreciate the responses!
On the note of the issue. I did have my step daughter climb into the rig and hammer the steering wheel back and forth. Saw some movement in the drag link ball joint connecting to the pitman arm. I then dove a little deeper and realized the tie rod ball joint looked pretty smoked aswell. Doing them both today if possible.
Another side note, put the Fox dual steering stabilizer on yesterday & why some people say it's merely just a gimmicky thing. It impressed me with how much it dampened the road feedback through the wheel. I'm genuinely satisfied.
Got this all figured out finally 🤞
After installing the new drag link and passenger side tie rod, getting an alignment & double checking EVERYTHING! It still felt like I needed a ton of input left or right to maneuver turns.... The alignment shop noticed the traction control light flickering (which it wasnt doing before) and said they looked for codes to clear, nada. They wanted to keep the truck to look over things more as it was the end of the day but I went and picked it up.
On my 33 mile trip home the traction control was acting up, flickering around right hand turns pretty severe. Hooked up Forscan and the only DTC present was in the TCU code U3000 -04 Control Module Internal Failure, see sub-type :04 can have power steering related issues. Cleared the code, took it out for a spin and IMMEDIATELY had my steering input back to stock. Drove around 15 minutes & code hasnt returned.....
So maybe if someone has the wandering, loose steering input after lifting dont necessarily think it's an alignment or loose component/improper install deal. Might be a simple solution. Hope this helps someone in the future.
.....And lastly the BDS Nx2 steering dampener is an absolute joke! Took it off to install the Fox dual stabilizers, compressed it & hasn't rebounded in 30 minutes. (Lift kit was installed 4 days ago out the box)
I hope mine was just bad brand new for others who keep it on but sheesh. Not a good look.
Last and final update..... Just to help someone in the future. Truck started steering oddly again so.....
I ended up swapping the BDS radius arm cams to the rear hole position (Recommends Hole facing forward for 5 inch lift) after seeing the 7in kit uses the exact same arms & also wants the cams forward facing considering my 7degrees of caster. The 2.5 inch kit recommends the cams facing the rear but HUGE IMPROVEMENT! No bullshit, I think that was the majority if not all of my issue. Coils aren't bending back whatsoever....
Now, onto the 37's! 🤟
Man, I missed the first update somehow. Super stoked you got it figured out. New suspension, front end and soon tires, Living the Lifted Life, love it.
I ended up swapping the BDS radius arm cams to the rear hole position (Recommends Hole facing forward for 5 inch lift) after seeing the 7in kit uses the exact same arms & also wants the cams forward facing considering my 7degrees of caster. The 2.5 inch kit recommends the cams facing the rear but HUGE IMPROVEMENT! No bullshit, I think that was the majority if not all of my issue. Coils aren't bending back whatsoever....View attachment 209992View attachment 209993View attachment 209994
Congratulations my friend! Glad you got it worked out. As you know, there are many tire threads so good luck!
Ha, yes indeed.
No worries my guy, will NOT be making a thread on tires. 😂😂😂
