Need Lower Running Boards
I ended up purchasing the Aires ActionTrac powered running boards. They are terrific. There are actually two steps. I chose these as they drop down lower than the AMP's. The top step is nice as well. You can stand on it and see the roof. My wife is 5'3" and these make a nice difference!
Pics for the brothers that may be interested would be nice. Plus I’d love to see your Beast. I think everyone is a fan of all pics. Good luck Bill.
GOD BLESS my man
How about a pic or two?
Has anyone tried using the running board brackets from a regular F250?
I did a cursory look on an FX4 and a Tremor at my local dealer and it looks like all the bolt up points are the same. According to my measurements, the FX4 step height at the tread lip was 17.5 inches and the Tremor tread lip was 21.5 inches.
It looked to me like the FX4 brackets would bolt up to the Tremor boards with no problem, and you figure that the brackets would all bolt up to the truck the same.
I'm looking to order a Tremor very soon and while I don't have a problem getting in or out of the truck, the boards being a few inches lower would just make life a little more enjoyable.
I don't know how much those board brackets from the FX4 cost, but I'm going to try and find out.
Stormtrooper69 - Any update on this set-up?
Yes, boards and or brackets from a regular F250/F350 will work, I just did the opposite. Nuts are easy to remove, whole process takes less than a half hour for the swap.
@Bad Man I have (6) that I bought from an FX4 ( they use (3) per side) The Tremor running boards only require (2) per side so that immediately gives me (2) extra. Let me know if you are interested - I would sell you (2) or (4) depending what you want. If I use them it will only be for the passenger side. I paid $180 for the set and will sell the individual bkts for the same ($30 a piece). They are used but in fine shape other than a bit of dirt...
I've heard mix things about the Aires boards. Not sure if it's fun or not. Those are the ones I REALLY want
Just curious if you considered lowering the stock boards vs. swapping over completely to the FX4 boards?
I did but it was worried that the lower boards without a way to use the middle bracket would cause too much stress or flex getting in and out with the added heights. The stock tremor boards cant use the middle mount since they are up higher and are less prone to a high angle pivot. Maybe they could be welded on but didnt want to go that route. It's temp anyway as I am waiting for AMP to support the 2022's.
Modman: Thank you for the offer. I don't have the truck yet, but was trying to plan ahead with the part numbers just in case my hottie wife wants lowered boards. Many months from now, when we get the truck, if she wants lowered boards I'll be in touch to see if you still have them available. Thanks again.
Sounds good! I bought these in advance of my truck arriving. I wanted to have a solution ready to go if the higher boards were a no-go for her. She is fine with them for now but since we plan on keeping the truck a long time we may have to do something down the road a ways...
Modman, if u still have those brackets id be interested in them.
I plan on ordering a 21 F-250 Tremor in near future. However, my wife does NOT like stepping up so high. How much lower are the power running boards? Or, is there a "clamp-on" step or bar that could be attached to the stock Tremor running boards? I really don't want the expense of something like the AMP power running boards.
Thanks!
Bill
Get the power running boards, you won’t regret it!
