Need help.... Offset and powder coating?
Fleece82
Tremor Buff
West Virginia
So I just got my 2025 Tremor. Im looking for replacement wheels. My truck is Antimatter Blue and I really want a gunmetal wheel. There are not many options out there in stock that I like. So I may end up having to buy another color wheel then have them stripped and powder coated.
Has anyone gone that route? Just curious if the coating will be as durable as factory?
There are a few wheels that I like but the offsets range from +20 to 0. I have been on the wheel and tire thread and looked at several pics. It really has me confused bc I'll see a 0 offset in one picture and think it looks great then another pic and it looks like way more poke than I want. Then same for the +18 or +20. Sometimes it looks perfect, then sometimes it looks like it is barely different than stock.
I do not plan to level bc of the squat I already get when I haul and have no desire to put bags on. So I will most likely be stuck to 35x12.5 unless there is a small for size 37x12.5 that I can fit. Either way can anyone that has a 0, 12, 18, 20 offset tell me how much your tires actually poke. Cuz all the pictures have me very confused. I don't mind a little poke, maybe an inch or so up front but I don't want anything excessive. I also understand the front will poke more than rear. Ideally I'd like to have rear about even to maybe 1/2" of sidewall poke if that doesn't result in too much poke up front.
Any and all suggestions would be appreciated!
Just remember "poke" is not just the offset. It includes the width of the wheel as well. A zero offset 8" wide will not stick out as much as a zero 10'" wide wheel.
Guess I should have specified I'm looking at 18x9 wheels. But I understand what you are saying.
There's a whole fitment thread but a good reference is going to Method or Raceline or whatever brand floats your boat and plugging in your information and they will spit their recommended sizes for your truck. You can go more aggressive if you like which it doesn't sound like you do. For example, on Method's site they recommend an 18x9+20. Probably lots of us have those exact sizes on here. As for rubbing and clearance, Toyos seem to be the only tires that will not rub anything with further adjustments.
Edit - you're probably seeing the tire as the poke. So you'd need to focus on the narrower selection, 11.5/12.5's and see what dudes have achieved the fitment you're going for. I wanted 37's on stock wheel really bad but I wanted Falken Wildpeaks, found out real soon they're too big. They rubbed in several places. This whole thing blossomed into like a 12k ordeal on my end but had I researched responsibly and learned only CERTAIN 37's fit well then I would have done it that way. My 2 cents
As for powder coat, depending on your local shop all kinds of things can be done. My Harley is basically all powder coated even the tins. A reputable shop can point you in the right direction based on what color you choose. As for cost, I'm not sure I'd guess somewhere between 600+ if the wheels are new and unmounted.
My local powder shop's wheel gallery
I did talk to my local shop, he told me 100-125 a wheel. Which I thought seemed reasonable.
I had a set of Methods done to closely match my Carbonized Gray. They came out prefect. The shop I used had their supplies from Prismatic Powders. They have a color catalog that is almost WAY too many options. Just ask they shop you choose what brand of powder they prefer.
As far as wheel size and specs : The biggest difference you will see is in the manufacturer. They may offer a few different versions of the same wheel, or may only offer one version.
Here's a visual to help :
iu
Even Method wheels shows the specs that seem VERY confusing between sizes. Some designs drive different specs. For tires : Some wheels might be on the narrow size for 35x12.5, so don't forget the LT metric sizes that are almost the same specs.
  • Like
Reactions: KR3
Not sure how this helps, but it does show some details.
Seems as Inset is a newer term for plus offset :
iu
  • Like
Reactions: KR3
Thatโ€™s about right. I did a set about 15 years ago and I think it was $75 per wheel. I ran the set on a track at way higher temps than you would see on your truck. I think PC is rated for over 500 degrees.
The nice thing about powdercoat is the prep is straightforward. If it isnโ€™t bare metal it will not stick before baking. The finish doesnโ€™t quite have the shine of paint and clearcoat but it is 10X more durable.
There's so many flavors of top coat/clear coat powders it's your choice how they turn out. Sure just a straight one coat powder will not "shine" but the that's what the top coat is designed to do as well as add another protective layer.
18x9 wheels with a +12 offset with 37'' AT3's clear with no lift, and the tire sits about 1/4" inside the top vertical line of the wheel well on my 2024. The tire fits the well very well. No pictures, but I ran that for about 3 weeks while I was waiting to get in and get my lift installed
Durability-wise, the wheels I have are powder coated and the guy said life on the powdercoat is more dependent on what and how you wash them with than anything else.
Speaking from experience powder coating a wheel will add material to the bore hole and makes them a bitch to get on and off. Then after a few install the powder coating will start to come off then on my steel wheels yeap rust. Just my experience with powder coating a hub centric wheel.
๐Ÿ’ฏ
Given a true hub bore sized wheel. Most aftermarket wheels tend to run into the lug centric application with a little larger hub bore. Now one could address to the coating company of this hub bore problem (as required) so they can mask it off.
This. Lug mating surfaces should be masked as well, ideally.
Ok you guys definitely have me leaning away from the powder coating route now. I'm not sure how experienced my guy is with wheels. They are more large manufacturing, frames, heavy equipment, etc.
Now my issue is the only wheels in stock I can find in a gunmetal color that I like are a 0 offset and I'm not sure how much that is going to poke me out up front. I'll be running stock tires for now then eventually move to a 35x12.5 or possibly 37x12.5 if they won't rub but have no plans to level or lift due to the fact that when I haul I'm about level with maybe a touch of sag and I have no plans of adding bags.
Some wheel brands will have better coatings out the box. Some are total crap. I think you are shooting yourself in the foot by limiting yourself to hub centric wheels. Which you are going to find are somewhat limited in offerings depending on the brands/models of wheels you end up liking. It's your call...the info is here. ๐Ÿ˜Ž ๐Ÿ˜Ž ๐Ÿ‡บ๐Ÿ‡ฒ ๐Ÿ‡บ๐Ÿ‡ฒ ๐Ÿ‡บ๐Ÿ‡ฒ ๐Ÿ‡บ๐Ÿ‡ฒ
I'll be honest, I haven't even been paying attention to if the wheel is hub centric or lug centric. I just been jumping from website to website trying to find anything I like that is in stock and available. If I'm missing a search somewhere that can broaden my options, just point me in the right direction! ๐Ÿป
@Fleece82 : Too easy to share my man. Look at the wheel specs (hoping they have them listed openly). 124.9mm is the OE hub bore size, give or take a few mm.
As an example : Method Wheels will run 130.81mm for hub bore. That's due to the lug centric design.
Generally speaking the type of lug nuts they may require can tell you as well. If you see them relating to Acorn style, that's likely a lug centric wheel as well.
Just ask questions if you want to have another 1,000 opinions on your choice of wheels! ๐Ÿคฃ ๐Ÿคฃ ๐Ÿคฃ ๐Ÿ˜œ ๐Ÿ˜œ
