Need help.... Offset and powder coating?
A few comments from an actual powder coater. I have formulations that will look BETTER then a wheel that has been wet sprayed and clear coated... Period. A good powder coat job is all about the prep, I won't coat anything I can't sandblast to put a proper profile for good coating adhesion. Worrying about coating mating surfaces, hub centric, blah, blah, blah... nope, no concern. We mask off mating surfaces and or vacuum back off the powder around the hub, mating areas etc. A properly powder coated wheel will last far longer then a wet paint applied scenario... ONLY IF DONE CORRECTLY. Hacks that don't do proper prep, are what gives the powder coating industry a swollen lip. Trust me when I say, all the labor is IN THE PREP!
Lastly if you were quoted $125-ish a wheel and they are chemically stripping the factory coating, sandblasting, doing an epoxy primer, base and clear... run with it. Lots of us are way more a wheel for that kind of work, especially when doing multi-coat, multi-color. I do wheels for an RV manufacturer (Alcoa Polished Aluminum Semi Rims), we remove decals, sandblast, prep and mask, then do an builder primer and a black final coat... I charge $320 a wheel. But that includes pickup and delivery.
Thank you! This is great info and I appreciate it.
I was quoted 125 and that may be a good or bad thing. Maybe this person isn't as thorough as you. I personally have never had anything powder coated. They are the only shop within an hour or two. So my options are limited. I do know he has been there since I was a kid and I'm in my 40s now. So one would think if his work wasn't decent he wouldn't ha e had the lights on this long. But who knows.
I did question him about the mounting points and he said he masks them off. Says he has done several sets of wheels without issue.
My limitation is I don't have a wash bay in my current shop, so using chemical strip is not an option. Thus I can't do an aluminum wheel that has been coated already (powder coated). Steel wheels are no problem, but I have to rely on my blast cabinet for the prep and I shoot steel grit. A factory coated aluminum wheel takes way to much cleaning energy to get all that pervious finish off, and generally will leave the wheel with noticeable scarring marks from the blasting. Thus I can't do them. And uncoated aluminum wheel or steel wheels no problem. But I am really handicapped by not having an easy way to rinse/wash a chemical stripper. Quick pic of wheels in process, getting ready to mask those that are already blasted.
Ohhh and when you can powder coat, nothing is safe... LOL. This is my box truck, I could not leave well enough alone and just put my logo R on it, I was having new rubber installed and talked the shop into putting it on blocks and letting me have the wheels for a couple of days.
It looks less like a retired amazon truck now.
