I can say 1000% there's NO WAY grease will purge and I can see it with mine installed and the mounting hardware torqued to spec. The surface faces of the mount tab were/are located in such a way that the shackle bushings and sleeve are face-to-face with the rear mount.
Please make a video showing a properly mounted and torqued to spec Carli rear shackle visibly purging grease out the ends.
Sure your spot on with the shackles not mounted into the rear mount tab. I knew that from the start...I purged the grease properly on the bench. AFTER install I was like...NAH....that grease will not purge the channels properly.
All it takes is any amount of gunk to bind up the channels....they ain't going to purge....it's not enough space to allow for proper cleaning of the purge channels.
Maybe I got a bad set with poorly aligned bushings....
