More than just a wrecked bumper call for advice
Hopsferdays
Tremor Fanatic
Washington
Army
2022 F-350 7.3
All, I already posted a classified in search of a black bumper. I may have tried to rip mine off with a rock (long story). However, I’m wondering if I should just replace it with an aftermarket option. I have the winch mounted (which did save my ass in said story) and would prefer to retain it. Points to consider: I don’t want to modify a bumper if I don’t have to accommodate the winch. I don’t have adaptive cruise just the forward collisions stuff. My truck is a 22 f350. No ultimate trailer tow so I might be open to a grill guard one. Any input is appreciated. See picture.
Oh man. I really wanna hear your story now. Sorry that happened though. I’m sure it’s disheartening. 😔
I hope this moment is just a great opportunity to build out a fantastic new bumper. Perhaps there is an aftermarket one that works with your winch and has a light bar and fog light pods or something cool.
It was very much type two fun. I know there’s a bunch of options and a bunch of people have done this research already so I figure someone will have some juicy input.
Other than the bumper glad everything is ok. I have the factory winch too and have not yet found an after market bumper that works with it. Best of luck; do let us know if you find one.
Unfortunately, the OEM Ford Performance winch is a unique design and is not a standard fit/mount. It's not compatible with any other aftermarket bumpers unfortunately. Now, I'm sure that it can be done, but this would be custom fabrication work.
Also, you mentioned that you have forward collision but not Adaptive Cruise, these two options use the same sensor behind the bumper so you very well may have Adaptive Cruise, unless for some reason that tech was removed on your 22 due to supply chain issues from Ford.
2 ways to check:
1. You should see the sensor behind the driver's side portion of the mangled plastic piece on your front bumper.
2. On the left side of your steering wheel controls, you should have arrows that point forward and backward with different distances between them. This is how you adjust the following distance on the Ford trucks.
Take a look at those two things and it'll let you know whether or not you'll need to do an ACC relocation kit when it's time for a new bumper.
2 ways to check:
My man! Do you think it would be possible to get a plug for the winch control fabricate it into an aftermarket bumper for access and then have a fairlead on the aftermarket bumper?
2 ways to check:
If pre collision assist and the adaptive cruise use the same module, I wonder why people have to pay extra to get adaptive cruise even though they already have pre collision on their build. Makes me wonder if adaptive cruise can be enabled with forscan.
I thought the sensor for Pre-Collision Assist w/AEB (Automatic Emergency Braking) was located in the upper windshield?
I definitely have it without Adaptive Cruise - seen it activate once or twice already. ...unless what you're talking about is something different.
I'm really hoping you're indirectly suggesting that Adaptive Cruise could be activated if you have the Pre-Collision feature? :D
Sell the factory winch and do a aftermarket winch/bumper combo!
Yep. We do things like this for customers all the time, especially when they go through insurance. Get paid for the expensive OEM parts and then use that cash towards the upgrades they really want.
My man! Do you think it would be possible to get a plug for the winch control fabricate it into an aftermarket bumper for access and then have a fairlane on the aftermarket bumper?
It's going to depend on the bumper you go with and how much room there is for all that honestly. Not saying it can't be done. But it may cheaper and easier to just sell the factory winch and go aftermarket winch with a new bumper. Unfortunately, there's just too many variables with how many aftermarket winch bumper options there are. Larger bumpers like Road Armor, Fab Fours, Ranch Hand, I'd say there's enough room. Tighter fit bumper like ADD's Stealth Fighter w/ winch option, it's a much tighter space and you're limited on which winches will fit that slot.
There may be more software or hardware to get the ACC to work vs purely collision warning. Or it may be a simple up-charge. Wouldn't be the first time a manufacturer has charged for a software change....ie. Porsche Macan S vs Porsche Macan Turbo - exact same powertrain with a different tune lol
My understanding is the sensors behind the windshield are for the auto high beams and auto wipers.
All, I have now discovered my foray into the realm of jeeps though not disastrous did mess some shit up. I will likely be needing to replace the gas tank skid plate although for how much shit people have talked about the factory one it did save my ass. Further I will also probably have to replace the now (very) bent front stabilizer bar. All steering linkage brakes driveline exhaust etc appear to be in good condition. For front stabilizer what should I replace it with? Hellwig? Also skid plate should I stick with factory or get the bigger aftermarket one or just leave the mangled one on it? Thoughts?
After doing a bit of research, it looks like you might be correct.
However, all of Ford's visual marketing material shows it sensing objects from the upper windshield. 😅
I have pre collision and there is no sensor mounted under the driver's side plastic near the winch. That area is for the adaptive cruise control sensor. Not sure the exact location of the pre collision sensor but it's not the same as the cruise control.
I took the front end apart on my truck to swap it over to the sport look. I found no sensors, I think it’s in the box area above the rear view mirror.
Regarding the sensors Someone somewhere on here is a ford tech maybe they can help us out @ccw @Regular Cab Duallies you guys know who I’m talking about?
@fordguy74656, if we can get him to return...
As for the bumper, I agree with others, and I too think you should replace it with an aftermarket bumper, even though you would have to change the winch setup. Protection from type two fun, as well as possibly protecting from deer and other drivers (depending on which bumper you end up with).
I'm going to reach out to one of my tech guys today at my local Ford dealership and see what I can figure out.
I would sell the Ford OEM winch tray, bracketing and fairlead on the Tremor forum and keep the winch and mount it on the after market bumper.
