- Jul 24, 2022
- 264
- 277
- 2022 F250 Diesel Lariat Tremor, Carbonize Gray, Black Appearance, Lariat Ultimate, High Capacity Trailer Towing Package
I had a weird audio issue on my 2022 F-250 Tremor Lariat: regular audio/music was completely gone, and only system chimes/alerts (like 9 and 10) were still blaring through.
Here is how the troubleshooting went and why some of the early steps missed the mark:
* **Fuse 28 & amp connector:** Initial AI advice pointed to Fuse 28 and disconnecting the amp. Folding the rear seat back down is a bit tricky, though using a box-end wrench (ring wrench) makes it about as easy as it gets. Pulling the amp connector and checking Fuse 28 changed nothing.
* **Buying FORScan + an OBD adapter:** Next suggestion was buying FORScan and an OBD-II adapter. After pushing back and following up the next day, the same AI walked that back and suggested starting with a 30-minute pull of **Fuse 32** instead—no purchases required.
The actual fix (Fuse 32 for 30 minutes):
** Pulled the yellow 20A **Fuse 32** in the passenger footwell fuse box (BCM) for 30 minutes, put it back in, and normal sound came right back.
Why the fuses behaved differently (and why AI still gets plenty wrong)
On the 2022 Super Duty, the audio setup is split across different circuits rather than one single switch:
* **Fuse 28 (15A):** Feeds the **amplifier** side. Cutting power there only power-cycles the amp, not the head-unit/audio control side feeding it.
* **Fuse 32 (20A, yellow, passenger footwell BCM):** Feeds the **Radio / Audio Control Module (ACM)** circuit. When the ACM gets stuck in a bad state or locks up audio routing while still passing basic alert/chime tones, power-cycling the amp alone won't clear the hang—draining power on Fuse 32 for 20–30 minutes lets the module reset cleanly.
Bottom line: current AI tools are still pretty clumsy with vehicle-specific wiring/fuse nuances and plenty of their first guesses are off, so always verify against your truck and start with the non-destructive resets before spending money on tools or parts.
Text create by AI Gemini!!!
