Leveling GAS Tremor
kylant
Tremoraholic
Lake Tahoe
What is needed (height) to level a gas Tremor?
I have always used Carli (and would like to again), but I don't think their gas springs will level a Tremor.?
what are good options?
i am not adverse to using a new full leaf spring set in the rear. Do the Carli leafs actually lower the rear on a tremor?
thanks
You may want to read through this thread:
I have. that pretty much just talks about ride quality. doesn't have any answers to my questions. thanks
You can piece you own together. Use a 1-1.5" spacer, whatever shock package you like, and a PMF trackbar. If the steering feels a little squirrely, throw a set of caster shims on it too.
Some older threads in the suspension forum:
Thread with measurements:
Reverse level:
Shackles:
Airbags:
The Carli 2.5 springs with stock leaves will absolutely level a Tremor. If you want a slight bit of rake back then add their Deaver spring pack. The add a pack leaves combined with the Tremor leaf pack makes the ride worse, so go full spring pack.
I’ve got a leveled 7.3 Tremor with Carli kit. Nothing in the rear as of now. Need to order the proper rear springs now that I have my final weight down. I carry a camper full time, so was waiting to find
Do you tow or carry big loads occasionally? If not, maybe get an F150 ;)
I find most leveling kits look unnatural and completely ridiculous when there's any weight in the bed. A small amount of rake is good for an all-purpose truck, and it helps with fuel economy.
Since you have a gas Tremor you can do a "factory" level with diesel springs. This keeps about a 1.5" of rake. I posted about it here. Just make sure you change your shocks as well as the Tremor shocks do not have enough travel for this configuration.
this
A couple points...
One general: most leveling kits will not truly "level" any truck. When people say a truck looks "level", it's usually actually ~0.5-1" high in the rear, truly leveled trucks (0" difference front to rear) actually end up looking low in the rear.
One specific to Carli: yes their leveling kits will level a Tremor as described above, leaving the rear just ever so slightly high. Their front springs bring the front of a non-Tremor gas truck up 3" and the rear springs (add a pack, full progressive, or Tremor block) raise the back up by ~1" so that it's at the same height as a Tremor (or a 17-19 truck since those trucks use the same rear block as a 20+ Tremor does). The Tremor starts ~2" higher in the front and 1" higher in the rear (has less rake than a non-Tremor), so the same kit brings the front up only 1-1.5" and the rear 0" but it's still leveled and will be at the same ride height as a non-Tremor truck running the same kit.
This doesnt apply to spacer lifts. If you did go the route of putting a 2.5" leveling space on your Tremor, you'd end up with a 1-1.5" squat in the rear :sick:🤮
realistically what can you do with a level truck ? drive to the mall i guess. possibly haul a dirtbike or couch but that might be about it
I have the Carli backcountry on my 250 gasser and the 2.5 inches has given me a bit of squat in the rear. If you're looking for just a level I'd suggest a 1 or 1.5" spacer.
If you were working your truck as hard as you think you do then you’d need bags anyways.
I put the Carli gas springs on my tuck and it rides much better now
