Incoming Soon To Be Tremor Owner from Texas
He is probably more knowledgeable about gumbo and red beans 🫘 and rice. Beaumont is basically an extension of Louisiana and 100 miles east of Houston.
Yes I am. Crawfish, gumbo, jambalaya, sauce piquantes, sacalait. Learnt a bit of cajun cooking while being in this part of the country.
Welcome fellow Texan! And I have no clue if the 0mm offset and 37's will work without a level/lift, but I did run a +18mm offset with 37's for a day on mine without issue so I'd give it a try. You need to check out the thread I started last year on the subject, I am pretty sure someone in there tried it with a 0mm offset and maybe even with a more extreme negative offset.
Thanks and I will keep digging.
Awesome! I had seen they would fit on a YouTube vid but wasn't for sure. Thank you for the confirmation on that!
1.5" level kit in the front is the only thing I've done that would be different. I also have slight flares, but you can see on the back they sit pretty close to flush:
Looks great! The 0 offset is def what I am looking for. With the 1.5" level on the front does your truck sit level now or did it maintain a little rake? I just do not want to have to deal with whole squat/air bag situation once I hook onto a load. Thank you so much for posting this pic. Looks great!
The front is still 1 inch lower.
