- Oct 4, 2022
- 1,227
- 2,020
- 2022 F350 Tremor w/ 50Ten Camper
- 2025 F150 5.0L.
Howdy!
Spent the day extending the upfitter cables from the utterly ridiculous location Ford chose. I extended nearly all of them to right below the passenger door with 10AWG marine grade cable as I really hope I never have to remove the exterior fender, interior fender liner, or snake my hand through that craziness again.
Question for you guys who know more about the upfitt cables than me:
If you were to power 4x usbs (totalling 4.8A) in the dash (phones, garmin inreach, ipad for mapping, etc) would you opt for a fuse tap in one of the factory slots located in passenger footwell fuse box, OR would you use one of the upfitter cables? I am currently thinking the "Battery Hot" cable (BN/RD) which is rated for 20A will be great, but it is also a pain in the ass to get said cable into the cab from the outside. Or should I be considering one of the others (see table below)?
Important notes:
Thanks in advance for your insight and I apologies if this has already been sorted out on another post here (I promise I looked....)
Important notes:
- Ignition only is preferred over constant on (I dont want to drain batteries)
- Powering 2x Blue Sea 4.8A fast charge USBs (9.6A total)
- I CANNOT use one of the upfitter switches for this purchase as all 6 will be used by the completion of the build.
