How long are your OEM diesel batteries lasting?
Used the napa code that shows up here about every quarter and threw in a monster set of odyssey's as I was at 3.5 years they started leaking and too many people here we're coming up with weird random electrical gremlins once voltage started dropping so bite the bullet as they say to avoid any issues.
Swap to the sealed AGMs of your choice and ride out.
I got just over 6 years out of my F450 Motorcraft batteries. They would no longer hold a charge at all. I replaced the Original Batteries with Odyssey AGM Batteries.
I’ve read a number of threads about the OEM batteries “leaking” and haven’t thought until now (duh) what is meant by the batteries “leaking.” On the top of the battery or in the battery tray below? I’m still on the OEM’s, 27K and within a few months of reaching the factory warranty expiration date. Thanks.
Around the top typically. It’ll manifest as corrosion on the connections.
If it’s leaking around the bottom that’s a bigger issue.
Thanks. Appreciate it and now I know what to look for.
What batteries is everyone buying? Thinking about a pair of Napa AGMs
Most important thing is is to get AGMs. Any brand of AGM is probably better than any brand of flooded. The post popular ones on this forum are Odyssey (orange) and X2 (blue). I just replaced the 2.5 year old batteries in my 2022 truck because a little corrosion was showing on the hold downs. They were still working fine, but I learned a hard lesson about terminal corrosion on my 2006 Super Duty. I cleaned and repainted the hold downs and replaced the batteries with orange ones. The blue ones look a lot better and I was going to go that way, but it would have been over a half hour drive each way to Batteries Plus to get them and the orange ones were available on Amazon Prime.
"Leaking" is a term used by most, they are not actually leaking, they are boiling or venting.
Batteries have a tendency to boil if the charge current is too high or if the battery is not accepting the charge fast enough to come to the full charge voltage. This is the likely scenario if the battery begins to fail due to age, overcharging, etc. This is monitored by the BMS and if the voltage does not achieve full capacity, the system tries to "force" it by applying the higher charge voltage to maintain a higher charge current for longer periods. (up to ~14.7 volts) The battery can't get to the full charge, so it boils and vents through the caps. The result is corrosion to the connections from the acid/water vapor. (A longer discussion for that chemistry...)
Though the chemistry is the same, AGM batteries do not vent; everything is kept internal in the absorbed glass mat. They have a relief valve that once popped due to pressure, cause the battery to be compromised and soon to follow, death. The AGM can accept up to ~15 volts before that is likely to happen. FLA batteries can accept even higher voltage for short terms without damage but will vent and lose fluids. The trucks BMS doesn't allow the voltage to go over 15 volts. (Unless there's a problem with the charge system.)
I have a set of odyssey's bc I've anyways wanted to try them. This is my first set (they're problem free and zero issues) but I have no longevity with them.
I will however say, the DieHard AGM platinum from advance auto parts have served me very well across two powerstrokes (6.0litres) for probably close to a decade of duration and my wife's 2022 Jeep JL battery just died and I threw one of those in (after I bypassed the stupid tiny secondary battery for the ESS/ASS System; if you have a newer jeep or Stellantis product I recommend the same). It's tried and true for me without the colorful premium (orange or blue) lol.
I've been researching batteries a little. Anyone have any experience with XS Power AGM and XS Power Super Bank capacitor. I've seen this combination used on diesel trucks. The Capacitor charges quickly. The diesel trucks start a little faster as well. I believe 04sshd is using this setup. Not anymore expensive than most AGM batteries out there.
3yr for ford batteries. 8 or 9yr for most everyone else
At 21 months my '22 diesel started having some electrical gremlins. Both were leaking and one was pretty close to dead. Replaced both with AGM's.
Valuable insight on the truck's BMS parameters, thank you.
Is anyone having issues with the OEM batteries on the gas trucks? I know the diesels are harder on batteries overall. I've had great luck with Motorcraft batteries in the past but spend a lot of time a long way from help. I run lithiums in all of our dirt bikes since none of the newer bikes have a kick start lever anymore, specifically the Anti-gravity with a reserve or "re-start" technology I think they call it. Curious how these trucks would handle a quality LiFePo4 battery. Solid state batteries are interesting but not sure they'll ever be viable.
XS Super Bank Capacitor
I haven't looked into this much but just a few minutes of research and I'm not so sure this is a great alternative to the AGM by X2 and Odyssey. Initial points to consider, for a group 31 (The largest capacitor I found 1000F at 8000 watts; 666 Amps at 12V) the CCA would only be 666 for a relatively short period. The original equipment batteries are 725 and X2 are 900+. Where this would make a difference is the "long crank" scenario. A capacitor discharges very fast upon high demand, there is no "reserve" capacity. It discharges at a logarithmic rate and may not last long if the truck doesn't start right away. On the other hand, it has a potentially high instantaneous current rate over a battery and charges quickly. This may be useful for a gas engine, but not so sure for diesel.
The capacitance curve is "typical", not battery specific. To charge a capacitor would require the same amount of current as the discharge. You can't get that from an automobile. I would also question as to how the BMS would work trying to charge a discharged capacitor of this magnitude.
Other caveats: 1-year limited warranty; From their warranty page: "For warranty service, the product must be reported to XS Power to receive a unique RGA number (return goods authorization) and at that time you will be advised of where to send the faulty product."
*M6 Terminal Hardware Included. Studs are available at a separate cost. :unsure:
$800-1000 for this size, depending on where you get it.
XS AGM Battery
The XS AGM may be a better choice but again, the smaller D6500 series have a lower capacity for the same size X2 or Odyssey and also uses M6 hardware again, would require optional studs.
(Not my favorite design, every "adapter" is equal to more loss.)
Warranty is 3 years, and though referenced as "Unconditional", here is the actual warranty wording:
X2 warranty is unconditional 4 years. X2 made in USA and available at all Batteries Plus stores.
No clue how you guys are fitting those X2 batteries in there since from the specs says they are a full inch longer than the XS group 65 ones.
Another battery post where I showed my XS replacement and having to melt the trays to fit the slightly bigger than motorcraft batteries
That XS Power Super Bank capacitor looks interesting, not sure how it would do with the glow plugs during the winter or if it would have enough capacity at 500 Farads, but at 10,000 amps that would start a truck for sure haha
and combined with an D6500 don't know if the BMS would try to over charge the system since you would have less total capacity. Plus as a capacitor it would always be drawing down the agm when it sat. Looks like more negatives then positives. But I might try something like that next battery change in 7 years (if these AGM hold out as they should.) run dual caps up front and have them topped off from the solar setup in the back seat.
If ya read the manual it says to charge it with a light bulb, your statement is not true at all need to do a little more research about capacitors :)
Got my oil changed today and the shop said my batteries both tested at 70%. Truck is 3.5 years old now. They said 3 years is "average life of most batteries now," but they're also trying to talking me into buy two $$$ new batteries.
No electrical problems, slow cranking, or any other symptoms that would indicate bad batteries. I'm thinking I'll check them again this fall. I'd rather have fresh batteries for winter than summer.
Thoughts?
My batteries were still good when I sold my 2017 after 7 years (but just 26000 miles).
Thoughts?
I snuck 5 yrs outta mine, and I replaced them with OEM from Ford dlr.
