- Feb 8, 2023
- 1,433
- 2,591
- 2024 F350 SRW Lariat 4x4 6.7L 3.55
- 2022 F350 SRW Lariat 4x4 7.3L 4.30 (RIP)
Thanks so much for posting this. Finding the damn passthrough wires was ridiculously harder than it needed to be. I would have never thought to look under the fuse box without your post. The SEIC harness was a pain but at least I could see it and I was able to fish it out with a long hook. The MY22 was a lot easier, but I must say Ford went to an extra level with anti-vibration tape on all the harnesses in the MY24.The pass through wires were taped into a loop right behind the horizontally mounted fuse box which sits just above the carpeted panel below the glove box.
The seic harness was a real pain to fish out. The white connector had a push pin, and was tethered to another wiring harness via this pin, accessible under the panel that pops out on the right side of the passenger footwell. It was located above and behind the large wiring harnesses that plug into the A pillar side behind the panel. I actually removed the trim pieces and door weather stripping in my search, only to realize it wasn’t necessary.
I bought a 22 kOhm potentiometer and with an additional 5.1 kOhm resistor I get a range of 5.1-27.1 kOhm or 1050-1950 rpm high idle. Found a nifty removable panel in the console pocket by the driver's right knee.
