Help with a connection (connector)
HeavyAssault
I'm just here to argue over your dumb posts
(Space for rent)
>>US Army<<
First Responder
Is she DAF or just ignoring me??
2022 F350 CCLB (11/2022)
2015 F350 CCLB 225k // 2006 F350 CCLB 280k
So there's this little bugger I've hoped to find the pair to mate. Its the connector on the DRW harness for the fender LED ID lights at each end of the DRW fender. Now by Ford this plugs into the LED housing, as of now I can't source a possible "mate" that would be a two wire pigtail of sorts. Anyone got some inside knowledge or better source to ID the possible two wire pigtail to mate??
I don't know how far you want to go with this but it's happened several times. It required a small piece of cloth, some alcohol and a rope. PM for more details 🤪
I've had pretty good luck with my local Ford dealer helping me identify pigtails. However, if I'm understand your situation correctly, when a pigtail going into a module, fixture etc. You are unlikely to find a mate to the pigtail you need. I'm curious, what are you trying to accomplish? Is there a reason you can't use a non ford connector or even a different ford two wire connector?
@TremorKR : I just wanted to avoid the whole cut-n-splice a new connector game. I agree when any of these OEM connections end at a module/light there's usually not any pigtail to find. I used the Ford catalog and even deep dove the workbook wiring (through the online Ford service) which all showed nothing available. I cross referenced my theory on several different things, all the same "ending" so to speak.
In the end I'm ready to splice on a DT, WeatherPack, or just straight wire-to-wire.
That looks to be a Molex brand connector. Go to their website and start searching. I think you might have some luck that direction.
Also, the pigtails i've seen... they all have a p/n of 'WPT-####'... if that helps.
1314 is the female end as pictured if I recall.
shoot... you did say 'pair to mate' in your post. My bad.
Does the connector align with these specs? (UOM = mm)
for additional reference: the connector model is 15B484 (Rear Side Lamp RH1, RH2, LH1, LH2)in the wiring book. Mine is print so I can't ctrl-f to see what other types of connections use this type of connector.
I would say yes, that is what I have in hand. I should have added the picture below to the first post. I didn't think about it till now.
I wish there was a better way to show this but this is what the pigtail would need to look somewhat close to fit.
HMM.. the photos appear only when I reply. They dont really help though.
If that drawing is close, its a Molex MX64. Start with Part number 31402 or 34977. There are -####s to the ends of those based on if the connector has clip slots, etc. While these are the part you have in hand... looking them up will typically yield the mate based on "what other customers purchased".
I've been successful with this method.
I added better pics. I think Bronc got the data set.
looks like 31403 is also a good number for the female.
All of the MX64 series use female terminals to mate with a module/sensor that has the molded in pins. You'll rarely find a light, module, or sensor with a length of wire on it anymore; usually only hot sensors (DPF/O2) will have a wire. They make it all one now to save $.
the same approach ive taken to identify mates with previous connectors is not yielding anything. Your information is spot on -> they just dont exist.
