Finally getting around to adding some airbags (Full Travel) to the truck to help with some heavier loads and can't figure out the best path for onboard air and air management. This is being added to a Pathfinder kit running their full progressive leafs.
My use case is a little different, as I'm in need of an onboard air system that can also air up 37's (probably 40's soon) in a reasonable amount of time. Most trips we're airing down and back up 2-3 times a day, which really adds up if your air system sucks. Looks like most of the kits people are running for airbag control are using pretty anemic compressors, and even with an air tank I worry that I'll still be wanting since these bigger tires are going to chew through that air tank pretty quickly.
I'm still researching and seeing what's out there, but my immediate thoughts are doing something like an ARB Twin Brushless feeding into a 2-3 gallon tank with a Pacbrake wireless controller for bag control. That'll leave me with a compressor that will keep up once the tank pressure drops during fill ups.
What are you guys running? Are there other compressors worth checking out with solid performance specs?
