If you want a PM I can, but I’m a fan of keeping the discussion public so others can learn as well. Also lets me post images easily.
Caveat: I’ve literally never used the product I linked to above or anything like it. I found it with a quick search and seemed to fit the bill.
Based on what I read, at its most basic, it works like a normal relay - apply power to the control circuit, it closes the contacts on the load circuit - but after a short period of time, it opens the load side back up, even if power is still being applied to the control.
Now, there’s an interesting mode that relay has:
In my head, this is the ideal mode as you can use a single timed relay along with two regular relays to simulate the factory momentary switch with your upfitter. Here’s how (again, in my head).
Your upfitter switch is connected to:
- Time-delay relay trigger input.
- Normally open control circuit of relay 1.
- Normally closed control circuit of relay 2.
The time delay relay load/output is connected to the load side of
both Relay 1 and Relay 2.
Relay 1 (normally open) is wired to the “On” side of the brain box.
Relay 2 (normally closed) is wired to the “Off” side of the brain box.
Here’s what happens when you flip the upfitter switch on:
- Power is sent to trigger the time delay relay. The time delay relay, seeing the trigger, will complete the load circuit for the programmed amount of time, then open it. This will ground out the load side of Relay 1 and Relay 2.
- At the same time as 1, Relay 1 (normally open) will get power from the upfitter switch. As a result, it will complete its load circuit, completing the circuit from the time delay relay to the “On” wire of the brain box.
- At the same time as 1 and 2, Relay 2 (normally closed) will get power from the upfitter switch. As a result, it will break its load circuit, ensuring the circuit to the “Off” wire on the brain box isn’t completed.
After the programmed delay, the time delay relay will break the circuit, resulting in no signal being sent to the brain box.
Note that Relay 1 and Relay 2 being wired to opposing normally open and closed means they can’t be active at the same time, preventing both On and Off signals from being sent to the brain box simultaneously.
When you turn the upfitter switch off, here’s what happens:
- The time delay relay loses trigger power. Because of the mode it’s in, it completes the load circuit for the programmed amount of time like before.
- At the same time as 1, Relay 1 (normally open) loses power from the upfitter on its control side and opens the circuit to the “On” wire on the brain box.
- At the same time as 1 and 2, Relay 2 (normally closed) loses power from the upfitter on its control side and closes the circuit to the “Off” wire on the brain box.
Because of the way this is setup, everything should inherently stay in sync. If the upfitter switch is “On” and you turn the truck off, the switch will lose power and the exhaust valve will close. But when you turn the truck back on the switch will regain power and the valve will open back up - no input from you required.
Something else worth noting: since you want to switch ground, not positive, you need to get the N variant of the time delay relay. They call that out on their page, but figure it’s worth calling out here.
Here's a quick wiring diagram I threw together to represent what I've described above. It doesn't include literally all wires involved, but the critical ones for my description:
