Has anyone done an exhaust cutout wired to their upfitter switches on their 7.3?
Those time delay relays are cool. You could use two of the negative switching type. Set one to trigger on 12 volt positive and connect the L (Load) terminal to White wire. Set the other to trigger on the falling edge of the 12 volt and connect the L (Load) terminal to Red wire. You'd have to play with the timings to find what works, but it would be an cool way to do it.
***This is assuming the brain box works like I assume above.
@ccw I think what I’m gonna try first is just mounting the factory switch and brain box Under the hood and shocking them with like 1 amp of twelve volt through a resistor to see what each of the three does. And maybe just use two two switches to shock the correct two wires at the right time and engage it remotely. I do like the time delay and relay box setup maybe if this actually works I’ll upgrade to that later. I’m trying to get this done tomorrow when my wife’s out of town lol
I think it'd be safer to ground the red and white wires temporally first, if that doesn't do it a little tickle of 12 volts would be worth a shot. Good Luck!
I think I get what you’re saying. For reference I’m gonna hook the whole shit up the way the manufacturer said to and clip it to a fluke and cycle it through to see what the separate positions do and how much juice they are using before I start getting funky with it. @Cory i was just rereading what I wrote and I was definitely unclear with my intentions. Yeah I’m not going rogue straight out and zapping shit I don’t know what it does. The way I wrote that original post that definitely looks like what I was gonna do.
Ah ok with that kind of time pressure agreed with your approach lol.
@ccw @Cory and for the followers of the saga.
Update 2: “that’s not how I thought this switch worked”
so the switch switches the ground that’s all it does so my new plan is as follows. I’m gonna go to oreillys and get two solenoids. Wire upfitter one to the brain for constant power. And then wire each of the two grounds through solenoids to upfitters 2&3. 2 to open and 3 to close all I need is a momentary connection of the ground to activate the brain to operate the valve. Thoughts?
Oh interesting. Well that works.
I'm confused why you're putting the constant power for the brain through an upfitter. Can't you just leave it with constant power at all times and solely have the switches for grounding it out?
… I’m a moron… yeah I can just run a hot wire to it through a 5 amp fuse. Then I can use switch one and two to do what I need. Oh also whoever thought that switch was gonna push “5 volts or something stupid like that” you were correct it was 5 volts hahaha
Or I could do it my way to be defiant and add redundancy in case my toddler or wife starts hitting switches there would have to be a sequence to get it right
Sounds like a plan! I look forward to hearing how you like the final result. I've always wanted to put cut outs on my V8 vehicles.
Couldn't you just wire one up-fitter switch to a standard automotive relay under the hood (https://www.amazon.com/dp/B01NBAO1SA?psc=1&ref=ppx_yo2_dt_b_product_details) and use the Normally open contacts to open the cutout and the Normally Closed Contacts for Close.? Up=fitter switch on = Cut out, Up-fitter switch off = No Cut Out
I don't think the brain box would like that. The switch it comes with is a momentary switch. Using a relay like that would be like holding that switch in one direction all the time.
Update 3: “it’s the right amount of loud I think”
First I thought it would be louder but it is sweet…
Second I tried to do the @paularchibald technique with some success and that is where I ran out of energy tonight. The brain gets confused with the constant supply of juice. It works ok but after a few cycles the brain gets confused and usually gets stuck in the open position. I think the single 2 position automotive relay is going to work if I can use @ccw s time delay switches in conjunction with that. But for now the factory switch still works and I disconnected a ground so I can use it that way for now until I get some delay switches but it definitely needs a pulse. But the sound is sweeeeeeettt just the right amount of loud and extra throat without being uncomfortable or setting off car alarms. Part of me hoped it would be louder so I could deafen people in riced up civics on command, but I will keep troubleshooting the wiring and get it perfect. I’ve also got some wiring to dress up but I’m too tired tonight. Will add pictures and a video for the sound later. Thanks for joining me on the journey and providing advice and ideas @ccw @paularchibald @Cory and everyone else.
  • IMG_3532.MOV
    311.1 KB
Under truck looking forward and back. That’s basically the farthest forward I could make it fit.
Glad your making progress, I have been giving it some thought But it’s the momentary switch that complicates it. I keep looking for some kind of sequencer that you could use one up-fitter switch. Toggle the switch on and off and the cut out would open, toggle it again and it would close. If I find anything I wiil let you know.
@Hopsferdays Thanks for the pictures! Looks good! I'm still patiently waiting on my truck so I get to "mod" in my head only at this moment.
@paularchibald You might consider a Vacuum Actuated Exhaust cut out. You could use a solenoid valve rather than a relay to "switch" the vacuum.
Crazy Idea: You could hook it up to the vacuum that actuates the front hubs, so when you're in 4x4 it's bypassed hahaha.
@Cory where tf were you when I was trying to pick this thing out. But it’s super cool and in that spot you get throat accelerating and loud when you want to be but just cruising it sounds almost like it’s unmodified I’m really pleased. I’m gonna keep dickering with it and will report back as I make changes and tweaks.
