Same here, I'd like to hear about these for the 23 model.
We are impatiently waiting for the design to get done for the 23 safes. It's driving me nuts.Please let us know when you have one that fits the 23. I do realize that the 23 console is much different from the 21 model. Also, I am hoping it can still allow the use of the charging outlet.
Sub'd awaiting arrival for 23's... It's not like it's almost 2024 or anything ;-)We are impatiently waiting for the design to get done for the 23 safes. It's driving me nuts.
The factory tray fits the E&G in my 2020.Did anyone find a tray that works with these?
If the factory tray doesn't fit, we have confirmed fitment with this tray here:Did anyone find a tray that works with these?
The 23s are just a shitshow altogether.Sub'd awaiting arrival for 23's... It's not like it's almost 2024 or anything ;-)
The 23s are just a shitshow altogether.No aftermarket support other than (basically) RC and Carli 3.5 lift, no bumpers, no electrical accessories, HECK i cant even put my vin in ford parts websites and find OEM replacement parts
I installed the eBay half vault today. I have a 22 and before install I checked my tray. It did not fit and I do not like the Amazon trays and their layouts. So I ground down the vault to fit the factory tray. I am happy with the outcome and although it
Yes, makes it nice when at the beach, river, etc. Also, it doesn't really matter where inside the fob is. I have found it the truck detects it inside, the door handle keyless is deactivated.So another cool feature I’ve found, and maybe this was common knowledge to others but I have not read it before. I have push button start, and with the key in the vault the truck can’t detect it (can’t lock from outside, unlock from outside by just opening door handle). I am effectively able to lock my key in the truck and use the door pin pad to lock or to gain access. Not something I would use often, but for a beach day it is nice to lock valuables including the key. Is there scenarios you guys would use this feature or not do it ever for risk of someone gaining access and having your key? I suppose if the battery dies in the truck during this scenario you could have always removed just the blade of the key for gained access without risk of water damage to fob. Although this could be stolen from belongings during a beach day etc.
So I just tried leaving key under the backseat. If I hit the lock button on drivers door and close door the truck double honks and unlocks the doors automatically. I can lock the door using the 2 pin pad buttons and the truck stays locked. Then I unlocked the vehicle, got in and started the truck no issue with key still under the seat. I don’t know how the truck would function in a forced entry and trying to use push button start in this scenario. I do know with my key in the vault. My truck flashes no key detected and will not start, if I have started the truck and put the key in the vault the gear lever locks on park and will not move to drive. I can lock the truck using the button on the door with no double honk and unlocking automatically.Yes, makes it nice when at the beach, river, etc. Also, it doesn't really matter where inside the fob is. I have found it the truck detects it inside, the door handle keyless is deactivated.
I gave up and got the full one again for my 23. Maybe the half is here by the time my 24 comes in.Any updates in regards to these half safes for the '23+ trucks?
I gave up and got the full one again for my 23. Maybe the half is here by the time my 24 comes in.![]()
It will truly be better. I always have run the full and have shit everywhere since it takes up whole console. Will definitely pick one up when they come out.I can't give up hope, I really want the half console so that I can retain some general space and the tray.
E&G makes one for the refreshed F150 which I think is a similar console to the ‘23+ Super Duty but that model currently doesn’t list the SD so hopefully they will be different as the design looks similar to the older ones that fit in the 2009-2014 F150 which is not nearly as solid in mounting as the 16-20 F150/20-22 SD model, eg. it doesn’t have a full metal frame the fills the entire opening from above and doesn’t through-bolt into the metal bracket below the console like the 20-22 specific model does it just uses large self tapping screws that drill straight into the plastic.Any updates in regards to these half safes for the '23+ trucks?
