Front Differential Leak
  • Staff ๐Ÿ›ก๏ธ
  • #1
Vermonster
Moderator ๐Ÿ› ๏ธ
Tremor of the Month ๐Ÿ†
Founding Member ๐Ÿ“œ
Meetup Organizer ๐Ÿšง
GB Coordinator ๐Ÿ“ข
Vermont
2022 Iconic Silver F-350 6.7 Tremor Lariat
Some BMWs & a Ducati 748 Mono
When I had my truck undercoated it was set-up to have dust stick to it (I used a Waxoyl from these dudes: https://www.byrnesrustproofing.com/rust-proofing) so it's pretty east to find a leak. It looks like I have something coming from the bottom of my front differential, and some random spots above it I need to investigate. Not seeing anything else anywhere.
I have the ESP from Flood Ford, so I feel I am in good hands.
thats what that RTV will do to you when you catch something just enough to break the seal.
hate that stuff.
made my own felpro gaskets to avoid the issue. I've had good luck with it so far. 40,000 miles or so.
good luck with it.!!!!
  • OP ๐Ÿ”น
  • Staff ๐Ÿ›ก๏ธ
  • #3
hate that stuff.
I didn't realize it was RTV out of the box. Likely will be again, :P
  • OP ๐Ÿ”น
  • Staff ๐Ÿ›ก๏ธ
  • #5
Now would be an excellent time to add the Carli diff guard, Lubelocker gasket, and drill and tap an NPT drain plug.
Great idea! :)
I see you have Amsoil gear oil AND the sliplock.
I thought the Amsoil gear oil included the necessary friction modifier needed. Is that not the case?
The reason I add it is it was recommended by Amsoil for eliminating any chatter. Easier to add it and not have to go back later.
Interesting. Completely missed that when ordering my oils.
Thanks!
  • Staff ๐Ÿ›ก๏ธ
  • #9
hate that stuff.
OEMs love it once the surface prep is figured out. Least expensive method for them vs. a separate gasket.
Allows them to have crappier surface finish too for the machining (see pumpkin housing above with rough fly cutting). The Lubelocker barely seals that.
  • OP ๐Ÿ”น
  • Staff ๐Ÿ›ก๏ธ
  • #12
Having the team at my dealer tackle this today. If it was summer I would do it myself - just a seal job today - if they do it. My guess is it will be one of those "we had to order the parts from Ford" but we will see.
Also having the state inspection, oil, and fuel filters changed per normal.
We will see...
Seems we are both without our trucks today. We should start a support group. Call me if you need to talk....
๐Ÿ˜ตโ€๐Ÿ’ซ
  • OP ๐Ÿ”น
  • Staff ๐Ÿ›ก๏ธ
  • #14
๐Ÿ˜ตโ€๐Ÿ’ซ
So true. I am sitting in the waiting room and waiting for the news. They all laughed at me as I put my magnetic front plate on the front bumper to pass the state inspection. After they got done laughing, I think they were proud. :)
