- OP 🔹
- #21
Not sure but most likely. Go to the Lube Locker website they have pics as well.
This is what I installed.
Does the front need Friction Modifier? It's my understanding that the "limited slip" with the front diff is a functionality of ABS module and the brakes locking up the spinning tire, not an actual clutch style LSD.
if you look at the first photo it appears to be a common front open diff. they must be just using the braking modules to direct power to the less traction wheel.
No, it's a limited slip diff. They look very similar to open diffs because you can't directly see the clutches.
The clutches are behind the side gears. Here's a pic.
Dumb question...maybe.
Since these trucks are not turning anything in the front diff unless in 4x4, shouldn't that fluid last....almost forever?
It's unlikely that the fluid will get contaminated from use. Unless you use 4wd a LOT.Dumb question...maybe.
It doesn't turn with a load on it, but it does turn. The minimal friction from the transfer case gears and hubs does spin the front.Dumb question...maybe.
I have a 2021 tremor, with the 7.3 gas. Would I have the Dana 60 front end, and the m275 rear end? Do you happen to know for sure? I'm trying to find the correct gaskets, and fluid for when I do a fluid change in the upcoming weeks.would that gasket be the same for all 22 tremors gas or diesel ? is there a part number for the gasket ? thank you
I’d hop down there and look, there should be some info on the axle near the pumpkin or if you shoot a photo of the covers someone on here can probably chime in.I have a 2021 tremor, with the 7.3 gas. Would I have the Dana 60 front end, and the m275 rear end? Do you happen to know for sure? I'm trying to find the correct gaskets, and fluid for when I do a fluid change in the upcoming weeks.
Thanks.I’d hop down there and look, there should be some info on the axle near the pumpkin or if you shoot a photo of the covers someone on here can probably chime in.
That is the rear, sorry if I made it confusing. I think it's the M275. ThanksThat is not a D60 with all those bolts. That looks like a rear differential to me. There are a couple of good threads on here about what differential is in what year model, use the search tool. If that is the rear just remove the bottom bolt and drain the fluid, if it looks good just replace and don’t remove the cover.
@Nick@ApolloOff-Road summed it up best:I have a 2021 tremor, with the 7.3 gas. Would I have the Dana 60 front end, and the m275 rear end? Do you happen to know for sure? I'm trying to find the correct gaskets, and fluid for when I do a fluid change in the upcoming weeks.
Thanks, again.@Nick@ApolloOff-Road summed it up best:
"All Tremors have the Dana M275 rear axle in them. Regardless if they are F-250 or F-350.
F-250 Non-Tremor Non-HD Tow Package has the Sterling Axle.
F-250 Tremor has the Dana M275.
F-250 HD Tow Package has the Dana M275.
F-350 SRW has the Dana M275.
F-350 DRW has the Dana M300.
All front axles are Dana 60. And Tremors have a front limited slip."
So you have a Dana 60 and Dana M275 rear.
