Works on my 03 cobra too. Do it first start after winter. On that car it just shuts off the fuel injectors so it can cycle without firing.
Has someone confirmed this works on the 6.7. He says in this video it doesn’t work on the diesels.
The manufacturer did include this function as OE. That's the point. Considering that Ford built this feature into the vehicle.... I'd say there was an obvious reason. Post oil service or anytime your vehicle has sat still for a time would place you into a dry start situation. I would not say you would need to do this every start... but you can't say the function is not important or purposeful because it isn't OE. If you are not interested or "feel" it's useless then by all means ignore it.I'm all for taking care of things but if it was that important the manufacturer would include it as OE. I get that the manufacturer only cares that it makes it through the warranty period and they don't want to spend any more money on things that don't directly benefit them, so that's why they don't do it. With the quality of today's lubricants and how far technology has come with regards to manufacturing and metallurgy, I think we're talking about something that in the long run doesn't matter because most of us won't keep the car long enough to ever have to worry about the engine wearing out. Proper maintenance intervals is the key.
That 80% or so of wear on start up is for a cold engine. Still, I like the idea of having oil pressure as soon as possible after start up. I prefix my oil filter for this reason.The why seems to be:
Whether that matters in any practical way is besides the point. But if it does, and holding your gas pedal down for a few seconds side steps 80% of the wear on your engine, why the hell not?
- “80% of all engine wear occurs at startup. The longer it has been since an engine was last started the greater potential for wear!
- Pre-Lubricating any engine before it is started will decrease or eliminate the overall wear normally associated with the "dry starting" of an engine, thus extending engine life.”
I was referring to something that pre-lubes the engine like the link you included.The manufacturer did include this function as OE. That's the point. Considering that Ford built this feature into the vehicle.... I'd say there was an obvious reason. Post oil service or anytime your vehicle has sat still for a time would place you into a dry start situation. I would not say you would need to do this every start... but you can't say the function is not important or purposeful because it isn't OE. If you are not interested or "feel" it's useless then by all means ignore it.
Think about the variety of situations after servicing or after extended sitting. Also consider the chain driven oil pump in this truck which was designed to enhance flow.... there is plenty of utility in this feature.
That was just a link which had info on the "why" and was not intended to highlight that product itself.I was referring to something that pre-lubes the engine like the link you included.
To expand on those risks for those who can’t/don’t watch the video: if you pre-fill the oil filter by pouring oil into the big hole in the middle, that oil has bypassed the filter. The inlet holes are the smaller holes around the edge, the big hole is the outlet.Interesting comments about the risks of pouring oil directly into the filter. Which seems to be a common practice on here.
This is not correct. The function that people are using to build oil pressure is intended to cycle the engine to clear an accumulation of fuel. It was not included by Ford to prime the lubrication system.The manufacturer did include this function as OE
Thanks for clearing this up!This is not correct. The function that people are using to build oil pressure is intended to cycle the engine to clear an accumulation of fuel. It was not included by Ford to prime the lubrication system.
The engine is still turning, mechanical parts are still interfacing at the same speed as they would otherwise in a normal start. This does not help engine longevity. I could argue that by doing this you are extending the time that the piston and cylinder bore interface at ambient temperature (vs operating temp) and, if anything, this will do more damage than good. Although it probably is still negligible in the overall scheme of things. Happy to argue tribology and thermo if anyone cares...
The reference to TikTok by @soop is closer to reality for this than you think. It really is another case of something going viral on the interwebs with no merit.
Honestly it isn't doing any harm - it is a factory mode after all - but it just isn't necessary. Didn't mean to come off as overly dramatic!!Thanks for clearing this up!
It is actually the opposite - to dissipate fuel without burning. It cycles air charge through the system without adding additional fuel through the injectors. This allows the in-cylinder mixture to reduce from an overly rich condition so that ignition can occur.Clear Flood mode to burn fuel
so this would still create oil pressure right?
