T
TremorGuest6137
Guest
I've never heard of this before and tried it on my work truck, 18 F150, and it works...
It's not. Let it crank for about 5 - 7 seconds.So just hold the gas pedal down while starting and let go after a few seconds?
I feel like this is some kind of TikTok Challenge trick…
So I tried it and there are two options based on starting mechanism.So just hold the gas pedal down while starting and let go after a few seconds?
Was the 5-7 seconds recommended to you? In the manual? Pretty neat. Reminds me of the old pre-lube electric primers...It's not. Let it crank for about 5 - 7 seconds.
DIG!! That's awesome! Yeah once a Batt Boy always a Batt Boy I guess ha. Was in from 99-05 active then contracted till 08. Put myself through college then worked in corporate risk management for 5 years running evacs and personnel recovery... and then decided to fully change careers for more family stability. Now I'm a GC doing Heavy Civil, Industrial, Commercial construction.@Tremor375 Ha. I saw your screen name and thought….hmmmm I wonder if this dude was…. Lol yep. I was in 2nd Batt. RLTW
Awesome! Yeah, I got out the end of 02 and also contracted until 08. Wife wanted to start a family so I couldn’t “play” anymore. I’m a house husband now!DIG!! That's awesome! Yeah once a Batt Boy always a Batt Boy I guess ha. Was in from 99-05 active then contracted till 08. Put myself through college then worked in corporate risk management for 5 years running evacs and personnel recovery... and then decided to fully change careers for more family stability. Now I'm a GC doing Heavy Civil, Industrial, Commercial construction.
How about you?
yes. It was recommended by a ford performance tech.Was the 5-7 seconds recommended to you? In the manual? Pretty neat. Reminds me of the old pre-lube electric primers...
Awesome! Cheers broAwesome! Yeah, I got out the end of 02 and also contracted until 08. Wife wanted to start a family so I couldn’t “play” anymore. I’m a house husband now!
1. Push button start as show in the video - power off, hold both pedals, push button and allow cranking... then release the gas pedal which as you release triggers the start
2. Key start - engine and key in off position, push gas pedal to floor, turn key to start and allow cranking, then as you release the gas pedal it triggers the start.
No TikTok China data mining, just Ford Tech
I get it, it works. Educate me on why you need to do it. Oil naturally sticks to the components even if you drain the oil pan. It's not like draining the oil pan magically sucks all the oil off of everything. If you pre-prime your filter, why would you need to do it? The oil is already stuck on everything from the last time you shut it down. It's not like the engine sat for months or years since the last time you started it. I'm being serious. I don't understand.He's right...It works
https://www.cpperformance.com/products/Oil/engine-pre-lube.htmI get it, it works. Educate me on why you need to do it. Oil naturally sticks to the components even if you drain the oil pan. It's not like draining the oil pan magically sucks all the oil off of everything. If you pre-prime your filter, why would you need to do it? The oil is already stuck on everything from the last time you shut it down. It's not like the engine sat for months or years since the last time you started it. I'm being serious. I don't understand.
I'm all for taking care of things but if it was that important the manufacturer would include it as OE. I get that the manufacturer only cares that it makes it through the warranty period and they don't want to spend any more money on things that don't directly benefit them, so that's why they don't do it. With the quality of today's lubricants and how far technology has come with regards to manufacturing and metallurgy, I think we're talking about something that in the long run doesn't matter because most of us won't keep the car long enough to ever have to worry about the engine wearing out. Proper maintenance intervals is the key.
