SuperDuty Lean/Fixing Tremor Lean with PMF Blocks
LetEmRun
Tremoraholic
Idaho
2022 F350 Tremor 7.3L
I have a stock rear suspension F350 Tremor. My drivers side sits anywhere from 0.5-1.0" lower in the rear depending on load/full gas tank etc. Drives me nuts - thanks OCD. I am planning to level it out by removing the factory block and installing a 3.5" PMF block on the drivers side and a 3" block on the passenger side to level things out. Does anyone know if I should get tapered block or just flat? Has anyone done this to fix their lean issue?
don't do that.
get 2* tapered blocks
If he is not raising the rear, then why? If oem tremor block is not tapered and he is only adding .5 with pmf block why get a 2* taper?
Now whether it’s a good idea in the first place to level the rear like that is another question. Everyone’s driver side sits lower than passenger from factory yet i do not see anyone doing this to please their ocd.
Hahaha well, I have a tundra with lean too. Added a 0.5” block on the drivers side. Years later no issues. But yeah, I am a little nuts when it comes to the OCD
If you have OCD you never want to use a level or tape measure on a modern vehicle, especially Ford, they are all off side to side (Every model too, even my GT500 is off slightly if you measure with a tape measure). I see it only being a problem if you eyes are picking up on it. The tolerance is just not that tight (not saying that it is right), it's just bad when all the extremes line up to give you that bad adjusted truck.
I get it. But yes, its noticeable even just looking at it from the rear. Sure, most people wont notice but it bothers me. So, is everyone saying their trucks lean just as much as mine?
If it bothers you and you can see it, then absolutly fix it. If it was my truck I would also.
Move all your heavy gear to the passenger side? That's my plan so far.
Also are the measurements with a full tank of DEF and Fuel? That's ~ 300lbs
lol. I guess using heavy stuff is an option. But not a long term solution
I have a 7.3 so just fuel for me. Heard this lean is being experienced by 7.3 and 6.7 owners alike
My 2017 had it....
Most all Super Duty trucks since 2017 if not a bit earlier have tapered rear blocks. Now that I think of it my 2015 needed a tapered block for lifting the rear.
Yeah, I’m going to give it a try. No reason to live with a lopsided truck
I don't really notice this on my 2023 but it was present on my 2017. Don't buy a Toyota with KDSS if this kind of thing bothers you haha, they vary in lean depending on where the hydraulic system is when you park it.
If you are still under warranty, it would'nt hurt to take it to the dealer and show them. You could just have a sagging spring and might get it covered under warranty, worth a shot. That is if you have a good dealer near by.
