I almost remedied with blocks in the rear but its clear that the sag seems to be more of a culprit in the front. Maybe airbags would fix things, but I think you still might have lean up front afterwords.
What are those rings made of, steel or a composite type material? Why did you decide to shim the front and not the rear? Maybe because of the weight difference with the front being heavier than the rear?
Steel. The front was more noticeable being off IMO. Also helped level out the rake more. Those rings are cheap as well $15 + shipping I believe for 2. So far, so good
Update for anyone who cares
This pretty much leveled out my front end side to side without any spacers, levelers etc. what I did was loosened every radius arm bolts and rock the truck side to side aggressively. And the results. The springs measured out a 3/16” difference with the drivers side slightly lower. Previous to that the truck would measure between 5/8” to 3/4” lower at the drivers side front corner depending on the surface I measured at, at that time. I did jack up the rear of the truck by the trailer hitch and the front springs measured identical to each other.
I tried the same in the rear since my drivers rear corner is a 1/2” lower then the passenger side. Nothing changed.
I measured front springs empty and with a full tank. The drivers side front corner sagged 3/16” so with an empty tank the front end should sit completely even empty. I’m thinking a nice set of quality American made leafs should completely straighten this thing out with or without a full tank. Hopefully this helps anyone with extreme OCD like myself
Or you could look at it like older street/strip drag racers do. They sometimes preload the right rear to preserve traction. The preload may compensate for driveline torque that would unload the right rear tire at launch.
If that new spring doesn’t work. Loosen all your radius arm bolts on a flat surface, rock the truck side to side and retorque the 6 bolts. I had anywhere from a 5/8-7/8”.
