I usually give mine a bath every time I go on days off. The interior I try to keep semi clean but man this moon dust out here mixed with all the wind and it’s impossible, even changing cabin air filters much more frequently than usual it doesn’t seem to make a bit of a difference
Sounds like you and I are in the same boat.
Having a dirty truck doesn’t bother me much, especially when working in the open desert—it’s nearly impossible to keep a vehicle spotless in such an environment. If I were in the city, it would be a different matter. However, the interior is a different story and must stay clean, so we make it a point to go through it once a week. The one thing I can’t stand is getting into a truck in the morning and already feeling dirty.
My rig is also used for work purposes in the Arizona desert and I’ve tried numerous cabin air filters, but it’s a constant struggle. I went from replacing it every oil change (120-150 engine hour intervals, roughly every 6-8+- weeks), to replacing it once a month. I order cabin air filters in bulk and I must have changed brands at some point but this summer, I was going bananas. The airflow was either nonexistent or severely restricted. Assuming the filters were clogged, I began replacing them every two weeks, which helped somewhat. However, with temperatures at 120°F and you're ooking for fresh dose of air to cool off with a cabin full crew, any restriction in airflow becomes unbearable. Out of desperation, I ran most of the summer without a filter, and the difference was remarkable. Unfortunately, I was advised against doing so due to the risk of premature damage to the evaporator, as the filter provides essentially it's protection.
Now I am running K&N lifetimes filters, after a recommendation from one of our members and no complaints yet but our weather has dramatically cooled, so our AC use is limited.
