G
Guest2542
Guest
That's called escalation of care.No, direct pressure is NOT applicable in all situations, sometimes a TQ is the initial treatment, but if you had any real medical training you would already know this
No. I never claimed to know everything.You know everything eh & when you don’t, you make it up and hope it sounds goodView attachment 34147
For what it's worth, I know nothing and I can prove it.No. I never claimed to know everything.
What is that little Gerber knife called? Also, are those titanium scissors?Additional photos in case anyone is curious
That’s a beautiful setup!
It's just called the strap cutter i think. i don't believe it has a fancier name. the trauma shears are titanium. it's been so long i can' remember where i sourced themWhat is that little Gerber knife called? Also, are those titanium scissors?
That’s pretty impressive! I carry about half of that. But heavy on the dressings,bandages, tourniquets, antiseptic,quick clot and small first aid supplies all inside of my aso REfactor bag. Rest of the bag I keep some extra clothes, survival gear, ammo, cleaning kit, hatchet, hammock water/food and plate carrier.I carry a small backpack -- like a student backpack -- with a very small side pouch that includes BandAids of various sizes, alcohol wipes, Polysporin, and pretreated burn dressings for the little stuff that comes up more routinely.
I'm going from memory here, so I may be leaving out a few things in the large compartment, but this captures most of it:
In the bigger compartment I carry shears, a very sharp knife, several sets of nitrile gloves, several tourniquets, plenty of combat gauze, kerlix, several large trauma dressings, a couple large non-stick (Telfa) dressings, a 40 ml irrigation syringe, normal saline, alcohol, two dextrose packs, a couple occlusive dressings, saran wrap, two hemostats, butterfly closures and suture kits, a couple Ace bandages, half a dozen chemical ice packs, two sharpies, epinephrine syringe, plenty of tape, an AED, a BP cuff, stethoscope, one-way valve-masks for adults and peds, and an ambu bag. It's not everything, but it's enough to be useful at the beginning of lots of SHTF scenarios, and it includes some stuff that's hard to improvise. I figure I'm just buying time...
Most of this stuff is crazy expensive at the local pharmacy, but pretty cheap in bulk online.
I’ve learned that if you might need cuffs, you really need two pairs (or leg shackles) because such a large percentage of Americans are now too fat to get their wrists close enough to fit a single pair of cuffs… If you disagree, go people-watch at Walmart for an hour.I ended up building my own kit. I do like a lot of premade kits out there, but I'd rather have everything I may need, everything I know how to use, and nothing else. It just makes the most sense to piecemeal.
I bought a pouch from Amazon a while back. It's got a velcro backer, molle front, and a decent pouch setup inside. You can see what's inside based on the pictures. For the ouch pouch, I keep Benadryl, Advil, Tylenol, and Tums for medication. That should be everything you need on a very basic level. One thing I don't keep in here but I do in my other IFAKs is an Albuterol inhaler. I don't feel comfortable keeping an aerosol spray in a hot vehicle.
And yes, that's a pair of handcuffs on the front of the IFAK. You never know what might happen out in the wild.
TruthI’ve learned that if you might need cuffs, you really need two pairs (or leg shackles) because such a large percentage of Americans are now too fat to get their wrists close enough to fit a single pair of cuffs… If you disagree, go people-watch at Walmart for an hour.
So very true. Went from cuffs, to hinge cuffs, which were a little bigger, to double cuffs to leg shackles. Then you have to worry about positional asphyxiation.I’ve learned that if you might need cuffs, you really need two pairs (or leg shackles) because such a large percentage of Americans are now too fat to get their wrists close enough to fit a single pair of cuffs… If you disagree, go people-watch at Walmart for an hour.
My foodsaver does double duty.Damn, reading back in this thread is cringe as hell. If you want a cheap kit alternative, but the components and but then in a vacuum sealed bag. It’s much cheaper and then you can customize the shape and exactly what you have in it.
It’s literally the best solution instead of buying a tacticool kit for 3x the markup. I made a perfect flat IFAK that sat right under my center seat in my. Had it in there for years, took it out when I traded it in for the 250 and it was as good as day one, still sealed perfectly.My foodsaver does double duty.
