One of my favorite channels,
And the fix:
And the fix:
No offense takenMan, what if you just used a damn screw drive hose clamp?! Fucking planned obsolescence is getting beyond ridiculous. I'll tell you what is fucking obsolete CEOs and shady engineers
No offense to any of y'all "CEOs" of non public companies and legit engineers![]()
Are you looking at the correct SPE one? Not the one for non emissions trucks correct?Reviewing both the SPE and the Mishimoto kits, Mishimoto brags about a check valve in theirs but no mention of a valve in the SPE. Does anyone know what it's for and is it needed? Other notable differences are the one piece construction on the Mishimoto and SPE states different routing with all tie points included. The stock part seems prone to failure so I'll just replace it rather than wait for it to leak. Just trying to decide between the two.
So I purchased the SPE re/route kit for my ‘24. I’m trying to see where exactly the re-route occurs? The new kit takes the same exact route as the OE. Did I just drop coin on something that wasn’t even needed? I understand it’s silicone instead of rubber but $160 is a bit steep for a hose. Curious if the changed the hose routing for the HO?View attachment 246213
So I purchased the SPE re-route kit for my ‘24. I’m trying to see where exactly the re-route occurs? The new kit takes the same exact route as the OE. Did I just drop coin on something that wasn’t even needed? I understand it’s silicone instead of rubber but $140 is a bit steep for a hose. Curious if the changed the hose routing for the HO?
(Hose overlay below for reference. Have not installed yet)
*EDIT*…Called and spoke with SPE. So I was under the impression that the kit re-routed the hoses away from heat sources. That’s incorrect. It re-routes the hoses if the EGR is gone. I ordered the correct kit. Basically replacing rubber with silicone, plastic with metal OE hose clamps with worm gear steel clamps. Worth it? Who knows but wouldn’t pay $140 if I’d known ahead of time.
I sent an email as well highlighting exactly what their website says. Not sure on this one. Definitely not a $156 part.I wondered the same thing. Took the factory off yesterday & installed the SPE. Still runs over the hot spots even though their website says the routing is different (mentions nothing about the EGR), and the top hose isn't long enough to reach the ziptie hose holder to pull it away from the heat. I took it off & put the factory back on. Sent them an email this morning as it was before they were open & they haven't replied. If you are goint to run it over the heat, provide heat shielding.
Is this something they addressed in the 23+ units?
The reroute kit for an engine with no egr is a different kit. Odd yours is listed as a reroute kit when the hose is different than the actual reroute hose kit, and I mean completely different. Here is the actual SPE reroute hose.So I purchased the SPE re-route kit for my ‘24. I’m trying to see where exactly the re-route occurs? The new kit takes the same exact route as the OE. Did I just drop coin on something that wasn’t even needed? I understand it’s silicone instead of rubber but $140 is a bit steep for a hose. Curious if the changed the hose routing for the HO?
