Ew engine on my 7.3 2022 f-350
Welcome to the club. Mine went at 29K miles. New long block under warranty.
Call Ford. In the most humble way ask for help. Tell them you are concerned about the longevity of a rebuilt engine. You want the person on the other end to empathize with you. When you feel they are empathetic ask for a new engine and extra warranty because you’re worried about future breakdowns. You can try the same angle with the dealer service manager, the 1800 person has been more helpful to me.
Good first step. That said, Ford was of no help over the phone after I wasted a lot of time with their customer service team. After my new long block was installed, I filed a complaint with the BBB and Ford finally gave me a 100K miles 7 year Powertrain ESP.
Hey JB,
I had a slight ticking , but more it was just the feel of the engine not being right. Also a rough idle . But before that I had strange shifting , then first warnings on my app. See attachment.
Started with an evap code, then grew into mis fire codes.
if you follow the prior tagged thread through the transmission issues i had. you should get a transmission rebuild too, maybe. the drums in these early generation transmissions had drum sticking issues. hence, hard shifting, hard engagement out of park.
yes US, Texas
no paperwork
i think i posted what i had
you'll get a year warranty on warranty work done. 2yrs for non-warranty work that you pay for.
bad batch of roller lifters are creating an incredible amout of headaches.
metal through-out the motor
I'll be surprised if you need to but i would only except a new longblock.
might be an attorney fight??? hope not!!!!
minimum on trans
have the fluid & screen changed.
on the premise of diagnostics for metal flakes.
if they find metal in the fluid then it needs overhauled.
good luck
Hey JB,
Thanks for the reply. Keep us updated on the progress and good luck sir.
  • Like
Reactions: Rpm
Need some Ammo when I go to push them doing a proper fix.
Reference the latest TSB (Technical Service Bulletin) which has the current logic/sequence to determine if it's the lifter issue and the next steps to remedy. Challenge them if they come up with their own root cause without using this guidance, which is the approved process from Ford for the dealer service department to use. Here is my post with the attached TSB and some excerpts:
Post in thread '7.3 Godzilla Engine Noise' https://www.fordtremor.com/threads/7-3-godzilla-engine-noise.18763/post-472389
I just re-read this thread to take note of the specific info you provided @Rpm . Following the service procedure in the TSB:
My answers to the procedure are as follows:
1. Yes - goto step 2
2. No - goto step 4
3. (Skipped)
4. (Filter removal)
5. Yes = replace long block
I’ve ripped GM many times on here about having to replace a motor at 106K miles due their BS lifter failures. Sucks to see Ford with similar issues on the 7.3L.
Good luck and hope they do the right thing and replace it under warranty
  • Like
Reactions: Rpm
Thank you very much!
I’ll keep you posted
2. No - goto step 4
3. (Skipped)
4. (Filter removal)
Yup, all those ducks are in a row, they said they cut the oil filter open and found metal fragments in it !
Well the time has come!!
Engine light
Misfire
Needs new engine!
Been in shop as they now need to send pictures to ford to see if I get a new engine or they will just put new parts back!! Under warranty fortunately
Anyone dealt with ford on this to say I don’t want parts but want a new engine considering there is metal fragments from lifter in the engine.???
Help
Does anyone here know approximately how many of these 2022 engines experienced this failure?
Ive read online that the 7.3L Godzilla failure rate is 2%. Someone above said at least 7 folks on this forum alone.
Call Ford. In the most humble way ask for help. Tell them you are concerned about the longevity of a rebuilt engine. You want the person on the other end to empathize with you. When you feel they are empathetic ask for a new engine and extra warranty because you’re worried about future breakdowns. You can try the same angle with the dealer service manager, the 1800 person has been more helpful to me. You can try the 1800 number multiple times, only need one of them to emphasize with you.
Getting pissed and going nuclear will result in scorched earth.
