Engine block heater
IMHO there isn't anywhere in the lower 48 where a block heater is worthwhile on a gasser. A remote start is much more effective. Spend your time and money worrying about more pressing issues in cold climates -- salt/corrosion, battery, traction...
I would agree for the most part, there are stretches of climates where it can be needed, like where I live. (I have the 6.7 though). But it's only 100 bucks on the order. Not exactly a bank breaker.
Why? According to many you'll be enjoying palm trees in your front yard soon. On the other hand I have palm trees a few doors away but I ordered one for mine - if the Zombie Apocalypse occurs in January I still plan on bugging out to Wyoming.
Wyoming is full. Go to Nebraska.
I ordered the block heater but now i’m also convinced to get the diesel cab heater option too. At first i figured i didn’t need it with remote start and all, but what if you’re somewhere where you can’t remote start ahead. Anyways for extra 250$ it makes sense to get it.
When adding the diesel cab heater it upgrades the alternator for free. 397amp
Yes, but not the other way around:) you can add dual alternators for 115$ and not add the cab heater. That's what i did unfortunately.
I wish i added them initially. Now my order is locked in 02 priority by Ford and i don’t know if i want to go back to 10 just for changing this one option.
I’m thinking what’s the worse case scenario, my cab will just take longer to heat up during very cold days? But how much longer is it really until the diesel engine warms up to start heating the cab? 5 ? 10 minutes?
And if i have the block heater (which i did order) running on prior, would it start to immediately warm up the cab?
Thanks, I believe I found them. I will absolutely not be buying them through my dealer. They are marking them up like 40% and not even willing to help me out even though the guy who puts the codes in for the orders left it out of my order.
Are they charging for parts plus installation. I wonder what the total cost is to do it post factory at the dealer
i can think of alot of places in the lower 48 where a block heater be worth having but to each their own . You can always hit your seat warmer while you sit while the truck gets warm .
It took over 30 minutes to reach normal operating temp with mixed highway driving last Saturday when it was in the mid 30s. That was with remote start for 10 or so minutes before starting to drive. Diesels take forever to warm up even under load.
I would have it added to the order even if it put me back at the bottom of the list. Not worth skipping in a northern climate.
Wow, i didnt think it would be that bad. Thanks for let me know, certainly worth considering.
Yeah I don’t understand how it’s not worth it when it’s -5 in the morning and your truck is warmed up in two minutes instead of waiting 10 minutes. Even if it’s only 15° outside and it’s snowed. it gives a chance for the truck to melt the ice and snow off the windows faster. To each their own let people do what they want. If it’s not for you don’t get it simple as that.
"Wyoming is full"
Full? If I climb my pecan tree I can see more people
than there are in all of Wyoming!
We like it that way. 😏
I lived in Great Falls, MT for 6 years in the '90s. When you get up to leave and it's 10-30 below 0, block heaters are definitely necessary!
I've been in -20 more times than I care to remember, never found a block heater necessary with a gas engine. I'd much rather hit the remote start than wrestle an extension cord in 20 below. Growing up in MN few people had block heaters on gas vehicles - and even fewer used them. Just my experience.
Well, we didn't have remote start back then. Everyone I knew used them. At those temps, you'll find out if your battery is weak. To each their own... I personally would opt for it and use it if still living up there.
