Today I installed the power cable for the block heater. I watched the YouTube video but it was pretty useless for my application. Unfortunately, the attachment points for the cable have been removed. I also had to be sure the cable didn’t foul the steering column. Where would we be without cable ties! I used one cable tie to mount to the top of the shock, another to a wire at the top of the spring tower and another around the ABS cable. With a bull bar at the front I gave up using the factory securing points there too, and just used a cable tie.
Again, with the bull bar in place I couldn’t mount the plug in the usual spot. i had to loosen the grille to pull the cable and plug up, then pulled the plug through the grill and cable tied the cable to the grille. Now I can easily access the plug.
