Engine Being Replaced - Help Me Out
Cab removal is the only way to even service many engine items, it’s one reason I choose the extended warranty. I would not want a cheaper shop to hack thru all the belts, hoses, lines, wires when the correct procedure for access is lift the cab.
67.000 miles in the ford shop now two weeks same issue i have fidelity 150000 mile warranty hope it covers a new engine. I chang oil every 6000 ford needs to eat this but I don't thank thay will. I bought my first ford truck in 1978 and a new one every 5 years I thank this my last FORD!
About where I’m at. On truck bought back. Trades 2nd in did to looking transmission recalls 3rd engine goes out before it leaves the lot. Now on my second oil leak.
jeez
Took mine in again for the oil leak yesterday. My front crankshaft seal, again. I called ford cuz I was pissed. I want a new engine. Their response was we can buy it back. They bought back my 2017 for more minor issues than this. I’d rather have just the engine but I’m also sick of taking it in. @boisefly I don’t know if you asked them
About buy back but that seems to be their default with me on three trucks. Maybe it’s MTs lemon laws.
Like others have said I would go with the new engine and contact Ford about an extended warranty, being courteous and kind goes farther than abrasive and rude.
These trucks are pretty much designed for the cab to be lifted for any major engine work so it's a fairly streamlined process for a competent tech (key word being competent)
Sucks to need a new engine in a truck that's only a couple year old but shit happens, hopefully you can get an extended warranty and sleep a little better.
I've had a 6.4 replaced at a Ford dealer and a 6.7 replaced at a non Ford shop and both have been trouble free after.
I did not. But it’s the first problem I’ve had, obviously a big one. Just didn’t bring it up so can’t provide feedback.
Well, I filed a complaint with the BBB about 10 days ago regarding Ford denying any kind of complimentary extended warranty on the truck. Wrote a full description of my situation and kindly explained that the circumstances validate an ESP provided by Ford. Got a response from Ford today and they agreed to providing a 7year/100K mile ESP. Didn't expect that but makes me feel a lot better.
nice, it sucks you had to press the issue but glad it's working out in the end.
Glad you got the extra warranty.
GREAT job there Boisefly! And, that is so GOOD that Ford stepped up with and extended warranty. Yes, it's unfortunate that you must apply pressure to get results from Ford. But, I have always thought that any complaints to Ford directly were pretty much ignored because you are just one (1) of, most likely, 5000 complaints per day, that they receive. Therefore, you're just a "number", NOT a real person yet. Sounds like you did your BBB complaint with courtesy and facts. Well done, Lance
I have had my tcase and tranny worked on under warranty and I was told there was an additional 2 yr warranty added by the dealership not Ford.
A got buddy had his 7.3 motor replaced at 9k '22 model took a month or so.....he has had zero problems since...let them replace the motor and enjoy your truck.
With the cam/lifter issues techs have gotten plenty of experience swapping 7.3s
Boy! That sounds like they did it pretty quickly. Yes, after driving your Tremor, an F150 would be a big "Step Down"! I am hoping that it is running well now and for "a long time into the future". Best of luck to you with your Great Truck & New Engine! Lance
Thanks. Yeah from diagnosis to full engine replacement took two weeks exactly. Not going to complain about that.
Do the replace and trad it in, simple.
Think about it this way. Your new crate motor was probably taken off the same line as the engine that will be in whatever new truck you might negotiate your way into was. So the probability of it failing in your current truck is no different than it would be in the new truck.
This makes perfect sense if the new motor really is “new”. I’d want to confirm that.
I don’t know how Ford does this, but when GM replaces an engine in situations like this the replacement is a “remanufactured” motor, which is different from buying a new crate motor.
I just had the Transmission replaced at 8K miles under warranty. The Receipt from the dealer will show the exact PN of what was installed, in my case it was a new Crate Transmission.
Should be similar for a new engine.
The engine plant produces a certain volume of engines each year solely for the purpose of service requirement like this. Reman is used if the engine is out of production and there is no remaining stock and/or the current production engine has changed to the point the assy or components are not backwards compatible. In this situation I would be surprised if it was anything but a full engine assy pulled from available service inventory and installed...
Good point. Going to look at the paperwork.
