Engine Being Replaced - Help Me Out
I watched several trucks undergo a cab off for engine work. My buddy had a shop and did plenty of work pull cabs. I can tell you after watching (and helping) pull a few cabs it's actually designed that way. It takes FAR less time to get to work on the motor. All the wiring connections are easy, they literally are form fitting to a point it's nearly impossible to not connect them correctly. The hoses are the same, they are molded to shape for a reason. Yes, there are some areas that can be a PITA. Body mounts are/can be points of concern given the age of the vehicle.
To bring this around to some points already made here : In the factory the cab is separated from the frame/motor the same way. Everything comes together so easy once it's time. Who wants to tear apart the whole grill, headlights, cooling radiators....etc etc over removing a few mounts, disconnecting a few harnesses, and then lifting a cab. Go find a local shop ask them to see a truck with a cab pulled, talk to the tech.
Similar procedures are common practice on cars these days too.. My winter beater (09 Volvo XC70) gets its engine, trans, and subframe dropped as one unit from the unibody for several repairs. The car has 200k trouble free miles on it and the last time I had it done was at 130k for the turbo and its oil feeds.
I think it all depends on the tech / mechanics that do the job. I have a buddy that owns a repair shop and every now and then the ford dealership brings him trucks to work on for major repairs. I don’t know if they think he is that good or if the dealership is just too busy to handle all the trucks in for repairs. Anyways, I wouldn’t have an issue with a new motor and say a 100k mile warranty.
If they were willing to give you a like for like trade for a brand new truck I would 100% take that deal instead by I highly doubt that will be an option.
Update: Met with their head tech in the service bay this morning and looked at my truck. He did say the cab is removed for a full engine replacement. He assured me that he has done hundreds of cab pulls and there shouldnt be long term problems because of it.
Both the dealer, nor Ford corporate will offer any kind of "Goodwill" extended warranty to me. Its just, were replacing your engine and youll be fine. Sounds like I'll be without my truck for up to a month...
Thats a bummer, did they clarify what the warranty will be on the new engine at least?
I'm also still curious if they've indicated what actually failed (or at least what they think failed).
To my knowledge, the warranty on the new engine is no different from the factory powertain warranty that is in effect currently. Basically, there is no additional warranty of any kind.
They tech was still in process of disassembling the motor to identify the exact cause of failure. They will call me once they find out and I'll update this thread.
I had to have the heads replaced on my 7.3. Day one before I drove it off the lot argued with ford about replacing the whole engine because that’s what the mechanics said. They didn’t, just the heads. It’s been fine but it has gone in once for an oil leak now it’s leaking again somewhere. I had a previous 2017 that ford did buy back. All of it is relentlessly calling them. In my experience they make it very difficult. No one knows anything. They don’t call back. Hard to get the same person twice. When you do talk to them. Get first and last names. Extension numbers. Where they work what office or area. Multiple times one would tell me something then the next was that’s not in the notes. All I had was a first name so went nowhere. First truck they bought back. Gave me msrp for it. My new 7.3. I told them to keep it unless they gave me their biggest warranty. After about 50 calls. I got 8yr 150k miles. Competent dealer mechanic is going to be tough in my experience. They leave clips off bolts out harnesses undone. All basically half assed as fast as they can get it done. I’d take pictures of all you could before taking it in. Hopefully your experience is better than mine.
You're the first to reply thats had actual problems with their 7.3. At what mileage did you have to have the heads replaced? How long has it been since the repair?
I filed a complaint with the BBB which doesnt mean anything, but I thought it wouldnt hurt. But gotcha, I could see myself calling them about 5-10 times but I dont have the patience to call them 50 times lol. Good for you for securing such a good warranty.
And yes, at this point, I can do nothing but trust that the tech working on my truck will do things right. He's been with Ford for 25 years and is one of the head techs at that dealer...for whatever that is worth.
Mine was at about 5 miles. Came off the train never made it off the lot. I drove it around. Was ready to leave and saw a tiny puddle under it. Antifreeze. Had warped heads from the factory. I was pretty much running on pure hate lol. I’m sure there are good mechanics at dealerships but seems all the good ones leave for better pay. After having one truck bought back. Traded in another for this one cuz 7.3 would be more reliable long term than the diesel and I didn’t the diesel and the engine was bad day one. I was nonplussed to say the least.
Thats insane. Sounds like you didnt have any problems with the repairs, right (other than the recent oil leak you mentioned)? How many miles on it now?
The dealer will either not help get an extended warranty or give him the run around, both or charge a fee for a warranty they get for free from ford. Call ford customer service yourself directly and ask for a “GOODWILL WARRANTY “. I had an engine fail on a squad car, it was replaced under warranty. I called ford and got a free extended warranty. Don’t be rude, explain your situation and that you’re a loyal customer… kindness goes farther than making threats.
Not if you have a good dealer that knows the system and you are a good customer. But if that has been your experience, which one was it? You or the dealer? But if they won’t, it’s easy to open a case and get the warranty extended. My dealer tells me to open a case as soon as things start going South. It actually helps them get help from Ford on problems when the customer complains. It may only be for the motor, but I have gotten 3 year 36000 mile bumper to bumper plus service on a EB and the same for my last truck that was plagued with electrical problems. Traded that truck in and Ford transferred the service plan to my new truck.
No other than all the broken and missing clips. Stuff not hooked up. Engine itself seems fine. 42k on it now. No idea if the leaks are related to the repair.
2022 7.3 F350. It’s within warranty and dealer thinks needing engine replaced.
For those of you who have gone through this, what have you requested from Ford in regards to new warranty? Is worth asking them to just forgo the engine replacement and just put me in a new truck? My heads spinning at the moment.
Don’t want the truck with a replaced engine and won’t trust it at all moving forward.
67.000 miles in the ford shop now two weeks same issue i have fidelity 150000 mile warranty hope it covers a new engine. I chang oil every 6000 ford needs to eat this but I don't thank thay will. I bought my first ford truck in 1978 and a new one every 5 years I thank this my last FORD!
Dude!! You don't think your warranty will cover it? Are you outside of your powertrain warranty?
Jeez - it's hard to hear these stories. Sorry you're going through this. Not a secret that all the US Truck manufactures are having their own struggles.
I have had engine replacements in other vehicles (not in a warranty) and it's one of the most straightforward repairs you can make - more so if it's a long block. Taking the cabs off is not as bad as it sounds.
Correct. These type of procedures for major component replacement are part of the initial design criteria. In other words, within reason, they are designed to be as least intrusive and accessible as possible, not an afterthought as it may seem from the outside looking in.
I have had two vehicles purchased back from me and two vehicles with engine replacements. Of the two vehicles with engine replacements, one is a 2019 Expedition (short block replaced due to fractured piston skirt) and the other is a 2023 Ford Bronco Sport (full engine replaced) due to flaw from the factory. I no longer have the Expedition as I traded it off on my 2021 F250 Plat Tremor. I have 0 reservation about keeping a vehicle with the engine replaced and fully trust the Bronco Sport. Generally speaking, if a vehicle with a replaced engine is going to have issues, it will be within the first few months and few thousand miles. However, I always negotiate some concessions from Ford in the form of extended warranty and on the Bronco Sport, I was able to score both extended warranty and a cash credit back.
Ultimately, it is what you can bring yourself to accept no matter what any of the rest of us advise as you are the one that has to square with it.
Keep it. You could go and trade it, eat the loss on the trade, and your brand new truck could have the same exact problems, more problems, or absolutely no problems. Getting a brand new truck doesn't mean no problems ahead, even though we like to convince ourselves it does. I went through this last year while battling my transmission issues and had to talk myself down from a new truck I really didn't even want. Another thing to consider, if your truck spends over 30 days at the dealer and you are making payments, Ford will reimburse you your monthly payment for every month the dealer has it. Call Ford Customer Care. If the person you talk to says they don't do that, keep calling back until you find the right person. They absolutely will. Did it on my truck and my wife's Expedition.
Hi Boisefly: I didn't have a Tremor but an F350 Crew Cab SRW PU with 14,000 miles on its Gas Engine and it was loaded with a 10'-6" in-bed camper and towing a 3 horse trailer to a Canadian Horse Show. The engine through a rod and came to a halt in the middle of central California near a small town called Los Banos. A nearby rancher saw us on the side of the road and stopped to kindly lend a hand. After unloading the 3 horses, we ended up un-hooking the horse trailer and the rancher towed the truck and camper forward enough so he could hook our trailer to his truck. We made arrangements with him to take the horses to his ranch and board them for us. We then had the F350 towed to the Los Banos Ford dealer and left it there for their mechanic to trouble-shoot the following day. (don't know what he needed to trouble shoot because the rod was sticking out the bottom of the block and the top edge of the pan ??). The next day, this dealer told us we had to remove the camper because they needed to change the engine with a new one from Ford. They towed the truck and camper to their back lot so we could remove the camper and store it there. We were told that it would take 2-3 weeks to complete the engine change. So, we left it there! Even though their "Heavy Line" mechanic was a middle aged and very knowledgeable fellow, I was very concerned because their service bays, at that dealership, were just a roof with one back wall and opened onto a 10' paved driveway then a dirt parking lot where the cars in work were parked. I had my doubts about the quality of their work?? Anyway, we made other arrangements with a different tow vehicle and made it to the Canadian Horse show, a little late. In about 2-1/2 weeks I got a call that the truck had the new engine in it and was ready to pick up - NO CHARGES. I had flown back home and my oldest daughter drove me up to Los Banos from the LA area to pick up the truck. When I got there, they had already loaded up the camper and it was ready to drive back home. I checked everything out visibly, thanked them and headed for home. That engine purred just like the original engine had and we put another 110,000 trouble-free miles on it before we sold it. Everything worked perfectly, no leaks, no noises, no rattles, no dents, no scratches, trans shifted as new and I was surprised but VERY PLEASED!
So, there is at least hope that your dealer will do a similar FINE JOB on your engine change and you will be back to normal and good to go, once again. I asked about extending our warranty which was 6 years, 100,000 miles which we were already into for 10 months and 14,000 miles, at the engine failure. They said NO further warranty extensions but that the New Engine included a separate 1-year, unlimited milage warranty that would supply a free rental truck, if that engine failed within one year (that came in writing from Ford & Dealer and was good at any other Ford Dealer in the lower 48 states). We never needed to use any of those things.
Beast of luck with your truck! I surely agree with all the other comments about NOT being rude but being persistent and in weekly contact with your dealer and Ford directly, if necessary. No one from the dealer or Ford was ever rude, dismissive or condescending but they knew that I wasn't to be taken lightly or pushed around much, in any case. That made it strictly business and easier for all of us concerned. That's my 2 cents worth, Lance
Great feedback. Thanks everyone for your replies.
As an update, I got a message from the dealer this evening before they closed. Ford approved a full new engine assembly as replacement. They sourced an engine out of Utah and it’s being delivered this Friday. Might have the truck back end of next week.
Will see how things go.
I totally understand how you feel but your worries will soon be no more. Kinda like when a broken bone heels, there is a time when you learn to trust it’s healed again and good as new. Positive thoughts!
