Edge EZX for 23+ PSD
I guess I hit a nerve.......... I'll go back to the subaru forum where I belong.
Don't think you hit a nerve. IMO you asked a question, where on this forum, most people modify their trucks. Some prefer to do performance mods over certain visual mods. It's all personal preference.
But yes, as for me I've never had a truck, car, motorcycle or sxs that I kept stock. I enjoy making them my own while also adding power over stock.
Nope, those of us who are happy with power are probably just ignoring. Watching for product comments. No reason to run.
You asked a question, we gave you an answer.
There is much more to it than just added juice. It encompasses overall performance and regardless of debate, engine longevity.
By removing restrictive components, you're essentially allowing the engine to breathe more freely, which enhances performance.
It's a win-win situation as mentioned.
seriously no heartburn here
it goes beyond that too though, the trucks are tuned for one specific reason mostly, driver comfort (I dont mean like plush comfort but comfort from the perspective of driving engagement to do work like in our instance) towing at max weight. The trans is lazy (not necessarily great for longevity but not terrible when you are towing 10-40k lbs ie in a 450) but also with the assumption that it might live life at max weight. A lot of these ECM and TCU you tunes (factory) are tuned with specific values and mantras in place, where also, good enough is good enough until there's breakdowns or rash of complaints, then an update gets worked on and pushed.
Drivability can be drastically improved and refined by custom tuners, to the individual basis bc their audience is drastically smaller than ford in totality (even just ford super duty trucks). All that to be said a tune is much more than just "peak" power there's a ton of other stuff that can be improved. I've seen instances where a tune might only gain 10whp peak but the other area under the curve in various spots could be 50-60 hp difference and a much more refined drive and power delivery.
Not mention fuel mileage. My normal commute to work and run through town in the afternoons I was averaging 17.5 to 18 MPG. After weight loss I am averaging 21-22.
Haven’t towed yet but will be in the next few weeks and can’t wait to see the difference.
The power added files were supposed to be added today for 20-25 trucks (no ecm swap required) but ezlynk had to fix one bug so they likely won’t come out until next week. Here are the power levels I’m being told:
2020-2022 Ford 6.7L Powerstroke Custom Tuning Package - EZ LYNK AutoAgent 3.0
Unlock the full potential of your 2020-2022 Ford 6.7L Powerstroke with our premium custom tuning package, powered by the cutting-edge EZ LYNK AutoAgent 3.0 platform. Designed for off-road and race applications, this tuning solution delivers unmatched power,
efficiency, and drivability with Shift-On-The-Fly (SOTF) capabilities and single power level options. Tailor your truck’s performance to your driving needs, whether for towing, daily driving, or high-performance racing.
Key Features
EZ LYNK AutoAgent 3.0 Platform: The industry-leading tuning device with cloud-based software for seamless tune delivery and real-time vehicle monitoring.
Shift-On-The-Fly (SOTF) Tuning: Instantly switch between power levels using a 5-position SOTF switch (required for SOTF functionality; sold separately).
No ECM/TCM Swap Required: Tune your factory ECM and TCM directly with the EZ LYNK AutoAgent 3.0, eliminating the need to send in your modules.
Custom Power Levels:
Stage 1 (Stock/Optimized): Enhanced drivability and fuel efficiency with no power increase, ideal for daily driving.
Stage 2 (Heavy Tow, 50 HP): Perfect for towing heavy loads up to 12,000 lbs, balancing power and reliability.
Stage 3 (Light Tow, 75 HP): Designed for towing up to 8,000 lbs or spirited driving, offering a blend of power and economy.
Stage 4 (Performance, 100 HP): Optimized for performance driving with significant horsepower and torque gains.
Stage 5 (Race, 150 HP): Maximum power for off-road and race applications, delivering unparalleled performance
TCM Tuning (Recommended for Stage 2 and Above): Enhances transmission performance by increasing line pressure to handle added engine power, ensuring smooth shifts and extended transmission life. Highly recommended for transmissions running Stage 2 or
higher. Please specify any transmission modifications when ordering.
Key Features
Just for clarity, what you mentioned is for the new version of what is dropping for the EZ Link devices not for the Edge EZX device, correct?
Correct, my recent post was for ezlynk tunes. Original post was for edge.
Key Features
Who’s tuning is this ?
I would venture to say that it’s AMDP?
Gotcha, gonna see what calibrated power comes out with I have no desire to do weight loss see what calibrated puts out for intact tuning via ez-lynk
I would just want to eliminate the dead pedal and make the throttle more linear. Truck has plenty of power!
if you haven't heard of, or used the banks pedal monster, you should try it. it works !!
I would like better drivability and get rid of the coasting dead pedal. I have no need for more power.
The AMPD post mentions TCM tuning, but I thought that they haven't cracked that yet?
Trans tuning for 23+ isn’t available yet
Ahh, that was for 20-22 only. Makes sense.
I want to do the tune, but am hesitant until they get the TCM tuning. I don't love the stock transmission tuning, and want to have that optimized before throwing even more power at it.
