Easiest way to make tremor not drive like a brick
Threads like this are odd to me. My first question (inner narrative) is if the poster has never owned or ridden in an HD truck solid axel vechile before. Not in a dismissive nature, more a curious one.
IMO the Super Duty Tremor rides better than any HD truck I've ever been in. Some folks who tow big pin or ball weights, or who have truck campers, might even say the Tremor has soft suspension for an HD truck.
Fixed it for you...
Lower the tire pressure especially if you’re not hauling anything. I run 55-45 cold psi and they warm up to around 60-50 psi.
My current truck is a 2019 F250 6.7L non-Tremor Platinum. I've ordered a 2024 F250 6.7L Tremor Platinum. Recently my dealer had a 2023 F350 6.7L Tremor XLT on the lot so I test drove it to see the ride difference. I took the 2023 Tremor across the same route as my 2019 non-Tremor... RR tracks, in town and highway speeds. Honestly, I couldn't tell much between my 2019 non-Tremor vs the 2023 Tremor. I've been happy with my non-Tremor F250's ride for 4 years and I'm sure my new F250 Tremor's ride will be just fine for my liking.
My FIL has a ram 1500 and when he rode in my 23 Platinum Tremor, he said it felt like a better ride compared to his truck. 🤷 I've driven many 3/4-1 tons and they are firm rides. But I think my 23 rides extremely nice. I aired down to 55 all around and it really makes a difference.
If you're looking for suspension upgrades to smooth the ride, I think you're going to be unimpressed and broke in the long run. Most suspension upgrades are geared for a purpose and all of them are not geared to make a 1 ton ride like a Cadillac.
I have a ‘22 Tremor F350. Best riding heavy duty truck I’ve rode in. It’s not a caddie but I didn’t think I could install a fifth wheel hitch in a Cadillac lol !!
Read through these:
Read through these:
thank you for all the helpful advice 🤙
When you say brick do you mean harsh? If so, don't put a rear sway bar on. A rear sway will make it handle better, but under certain conditions make the ride harsher. Also, be careful about shock selection, some have said the Bilstines make the ride firmer. I like the ride of my 2022 Tremor. It rides a lot better than the 2011 F250 that it replaced. I do have a cross-bed toolbox with about 250-300 pounds in it which helps a lot.
I just need to get some of the rigidity out of it. Back went out n the rigidity isn’t helping. But thx for not bring a troll.
Trade it for the same color F150 and slap a Tremor sticker on it. Most people from the outside won't know.
wouldn’t that just be a F-150 Tremor.. back under your bridge “founding member troll” lol
Let your husband drive it and you drive his ride? I’m just kidding! I have had all 3 brands of HD trucks in the last 2 years. I drove Ram from 2010 through 2021 until they made me mad. I swapped to a GMC 2500 in 2022. I hated it. I swapped to my current 2023 350 Tremor this year and love it. The Ford, in my opinion and everyone else that has ridden in it, thinks it is by far the best riding 1 ton that they have ever ridden in. The Ram was the worst. It felt like you were riding a 3 legged mule with arthritis. If you are trying to get a 1500 ride, you will go broke and still not get it.
Great advice “founding member troll” back under your bridge..my back went out and just lookin for some advice in the Tremor community
.... Jesus Christ what a bunch of trolls 😆
Air the tires down to 60psi across the board. It makes a big difference.
Cheers 🍻
Or even 50psi. That's what I run when not loaded or towing...
I drove my truck at the dealer yesterday and it rode Rough. then I checked the dash and yup, 65psi front / 80 psi rear. No wonder my test drive F350 with Zero # in the bed was a tad truckish.
Serious Question,
What is the Factory OEM TPMS nanny set at for PSI? At 50 you dont get a warning light ?
I'm going back to pick it up today and want the TPMS set at 45 so I can run 50 psi if I want
Serious Question,
I had to adjust the TPMS threshold in Forscan to run 50psi.
I could run 60psi at all four corners (as @Briski stated) when I first got the truck without an issue but I have an F250 so the threshold is lower.
My recollection is that 20-25% low will trigger the alert. You can try 60psi and see if that works without an alert. I think you will notice the difference.
There are probably some forum members close to you that would be willing to help with Forscan if you're not familiar. I'd be happy to help remotely if necessary...
  • Useful
Reactions: MVI
^^ Thank you for the kind offer. My dealership just called me and said they are not allowed to lower the TPMS Nanny Value xx psi the F350 as part of the PDI, So it looks like I will need some initial help to get this adjusted.
Lowering tire pressure is the easiest way to improve the harsh rear suspension. Unloaded, drop the rear pressure to 45-50, front to 50-55 (7.3).
But I consider it to be remarkably good suspension for what it is capable of carrying. Very happy with it.
My complaint is with the wandering steering. It gets tiresome to always be correcting it, instead of it wanting to go straight. I'm wondering if caster shims make much of a difference. Any comments from those who have installed different shims?
The low pressure light in the rear comes on if you drop below 64psi . So go out in the morning when it’s cold and lower it to 64 if you don’t want to see the low pressure light pop on.. if you do trip the low pressure sensor below 64 psi fill it back up to 74 PSI that will turn it off. Then bring it back down., The front is kile 54psi when it trips the warning.. I don’t remember off hand. But just do the same as the rear.
The one time I had a TPMS light go on it was exactly at 20% bellow sticker pressure. I think the federal mandate might state no more than 25% difference.
I did lower the threshold in Forscan and now run about 50 rear and 52 up front empty (6.7l). With the gas engine I would probably go even lower up front and have considered going lower in the rear. I may try 45 out back.
Bilstein 5100's. Steering Stabilizer, and Rear Sway bar all help significantly with handling without breaking the bank
At the end of the day its a full size heavy duty truck, Its not going to handle like a sports car.
Why the rear sway bar? Doesn’t it stiffen it up even more?
Do like I did----buy a 2024 2500 ZR2. Gets a little better mileage on the same roads on and off road as well only have 3k and it is a month-old next Sunday. Goes places in 2wd with just the reax axle locked where my Tremor took 4 wd. This is using the same tires on both vehicles. BFG HD Terrain's
