Disaster Prevention Kit - - yes or no?
You would think for the disaster prevention kit, especially the new version that adds the filter to protect even the return fuel, Ford would absolutely not mind this as it would limit their cost to repair under warranty as well.
I will be putting one on, but I decided to wait until I hit the three years/36,000. I still have the premium extended plan but at that point covering just the CP4 itself, even if for denied, it wouldn’t anger me as much.
I may be wrong, but I assumed the warranty for the CP4 is 5yrs and 60k. Am I wrong? If so I better get er done.
Say what! Not covered under ESP extended warranty?
Having been a Ford Owner and Loyalist for over 40 years this issue and Ford’s handling of it totally frustrates me. I know for a fact that Ford knows exactly what the failure rate is. Another known fact is that GM uses exactly the same Cp4 pump from Bosch and recently “settled” the class action suit that their owners filed successfully to a resolution. The settlement stipulated “no fault on GM’s part” but that’s standard settlement boilerplate. So to think that there is not at least an “above average” failure rate is a put your head in the proverbial hole in the ground look the other way position. I directly wrote the Law Firm handling the GM class settlement and they told me directly that they couldn’t talk about Ford.
All that being said the issue of warranty applicability is a very real concern. I’ve read on this forum before on this topic that an owner had a Cp4 failure that Ford covered and replaced the pump but then had a subsequent more expensive full injector system failure due to contamination about 400 miles later that was not covered.
Another factor to think about is Ford (and likely Bosch) claims failures are due to contaminated fuel. Well GM owners buy fuel from the same places we Ford owners do and that didn’t fly in their litigation defense apparently.
So do we have a lawyer amongst our group that could go down the class action filing road for us? Discovery analysis would uncover the true failure rate from Ford! I for one would gladly contribute as part of a group to cover initial legal filing expense. That’s just my two cents!
My understanding is that when a CP4 fails under warranty, Ford has a "kit" that is installed. This includes injectors. Ford covers materials and workmanship for 2 years after any dealership repair. Why would failed injectors NOT be covered?
Here is my two cents on this:
A prevention kit will not contaminate your entire fuel system should the CP4 go out; you're already ahead $12-14K
If the warranty were to cover your claim, even with you "altering" the fuel system (which is arguable since you're not altering but protecting yourself from a known issue), they would just install another cancerous pump. It's not like they're replacing it with something better, so you'd still end up back at square one, unless you have a good relationship with a stealership and they can swap in a DCR -- I think some have gone this route.
There are no exact numbers or statistics available, but the failures mentioned seem to result from operator error or negligence. Stay proactive with maintenance and consider using additives.
Why worry about warranty when you can get rid of the cancer all together? You won't need warranty then.
You have a solution to the problem, yet to avoid voiding the warranty, you let it persist until the warranty expired before taking action yourself? You could have done that earlier since you’d end up dealing with it alone anyway. That thought process just doesn’t make sense to me.
A permenant solution is a DCR swap.
This. All of it.
I can attest to the DCR swap upon a CP4 fail at the dealer. My shop told me that they would have no problem installing the DCR "under warranty" if my CP4 failed, All I would have to supply is the DCR and the labor would be on them. I'm sure that's not a legit deal, but they cook the books. I'm fine with that.
I installed the DPK before the DCR came out. Had I waited, I would have just said F it and gone DCR instead . Sure it's more dollars. But it's a cry once thing.
Although, now ot is so.eone else's truck with the original CP4 at 100k and 10 years. So they would have the DCR.
I know. I wrestle with whether to buy ESP or not about every six months.
You really have to read the coverage of the esp . I had the roof trim piece come loose / break at the rear window and was approximately 1k out of the 3 year 36k factory warranty and was told that my esp didn’t cover it. It covers some just not all components like the factory warranty
Just got off the phone with the service advisor at my dealer. Asked about CP4 issues under warranty and he said they’re not as common as folks think they are and that they have only dealt with a couple (and they’re the largest Ford dealer in KY).
Sounds like he’s got a knowledge of the Magnuson-Moss Warranty Act (although I don’t think he knew the name). I specifically asked him about the DPK while under warranty. He said and I quote, “It’s the same for any aftermarket part. If they can prove that the part let to the failure of the system then it will void the warranty and it will not be covered.” He wasn’t sure why I would want to add another “fuel filter” to the system but I don’t think he quite understood how I was explaining the DPK to him.
Anyway, looks like I may be ordering the DPK after all.
No offense, but there seems to be a contradiction either on your part or his. He appears to have knowledge of one aspect but lacks understanding of another. His response was a generic disclaimer, offering no substantial answer to your question and instead emphasizing that you are responsible for any unauthorized work. Essentially, you were not given a satisfactory response, which is unfortunately to be expected. It is evident to all of us that the DPK will not damage the fuel system. It is designed to mitigate the harm caused by prior components installed by this company (Ford), though they would never admit to this, as such an acknowledgment would be highly risky. It is likely that advisors are instructed to avoid confirming this truth.
What exactly are you referring to as the contradiction?
I won’t argue his lack of knowledge. I tried to explain a few times what the DPK is. Unfortunately not all SA are diesel mechanics and therefore do not understand the fuel system of the PS engine. I could hear the long pauses on the other end of the phone when I expected a response for him. I’m not going to try to give a whiteboard diagram explanation to him.
My primary objective was to see if I would receive an initial “Yes…it will void your warranty.” Then I know what I would be up against should the worse case scenario arise. I got the impression he understands Ford cannot just “void” a warranty. due to aftermarket parts. I was satisfied with his response. Easy peasy.
I didn’t interpret it that way; instead, they might try to void your warranty on the basis that it wasn’t authorized.
In my experience with SA, they are very direct and transparent, often clearly stating whether something is acceptable or not, without any ambiguity or general disclaimers, that go without saying.
I wish I could find that thread where the writer said they didn’t cover the injectors that went out 10 days later and used the “dirty fuel” excuse as poor maintenance. But this is what the post said.
OK, interesting conversation with the service dept. today at another local dealer where my truck is having some cosmetic warranty work done.
Posed this same question to them. Their response was, “While the truck is under warranty, make Ford pay the bill.” The amount of evidence Ford request they send them after a CP4 failure is pretty extensive. They said they’ve only seen one failure. They gave the same answer re: aftermarket parts but reiterated “Make Ford pay the bill” and do not give them ANY additional reason to deny the claim while under warranty, which by the way they have only seen happen with DEF in the fuel.
Interesting to say the least.
They said they’ve only seen one failure.... do not give them ANY additional reason to deny the claim while under warranty, which by the way they have only seen happen with DEF in the fuel.
So Ford denied the warranty claim on the only CP4 failure they've seen? Seems like a good argument to get the DPK 🤷🏼‍♂️
It seems that you and I interpret things in different ways.
What insights or understanding did you gain from this particular response?
DCR for me.. to many horror story's from Ford denied claims. Then getting your auto insurance involved is crazy..
I met a fellow a couple months ago at my local dealership, he was telling me he was on the way to this dealership to trade his 21 in on a new 25 (deal was done) and his CP4 exploded with 72k on the clock. He says he had run a fuel additive since new. Long story short Ford Denied his claim and advised him to turn it in on his auto insurance.. THEY charged him $17,000.00 to fix it.. hell naw!
Not sure what there is to interpret? I’m simply stating what I’ve been told. You interpret that as you’d like. Every person should decide for themselves how they want to go about this situation that may never happen. Don’t just go off what you’re being told by a dealer.
I appreciate all your insights and opinions but I don’t want to get in a keyboard argument (not at all what I was aiming to do) with you over semantics, with all due respect.
That's a standard defensive response rather actually answering my honest question.
Break a leg dealing with Ford.
Thanks for playing.
