Disaster Prevention Kit - - yes or no?
The concern is definitely real, but it’s also hard to predict actual failure odds. Some trucks go 300k+ on the factory CP4 with no issues, while others fail much earlier. Fuel quality seems to make a big difference. Personally, if planning to keep the truck long term, I’d probably install the best cp4 disaster prevention kit sooner rather than later just for peace of mind. Compared to the cost of a full fuel system replacement, the kit is relatively cheap insurance.
Peace of mind yes only for this potential issue. There are a lot more catastrophic issues than this alone. As others have stated it is not common. Plenty of trucks out there with 200k plus and zero issues.
True or False: The DPK will void your warranty? From what I’ve been told the answer is True. So while the truck is under warranty I will not install it.
I spoke with my dealership about this last week, and they said the DPK will not void any warranty. They were actually suggesting that I install it. That said, as long as i'm under warranty, I don't see a reason why to bother with it. If something happens, the warranty is replacing it, so at that point, I'm just saving Ford money, not me.
The warranty topic is an interesting consideration.
You have two options:
1) Install a DPK and you are taking a medium probability that a dealer denies a warranty claim on a CP4 failure, leaving you out of pocket for a new fuel pump (at which point you're a fool if you do anything other than a DCR conversion)
-or-
2) Don't install a DPK and you are taking a maybe much lower probability (but still not zero) that you have warranty denial due to fuel quality/gas or DEF in the fuel/service writer had a bad day/etc. leaving you out of pocket a full fuel system replacement
Or... cut the cancer out entirely, do the DCR conversion and never lose another minute of sleep over it.
