Disappearing Coolant
Took it in this morning...they pressure tested the system no leaks...Service rep is going with an air pocket in the system from the trans swap.... 🤷‍♂️
Then I got the "adding a half gallon isn't really a lot when you consider it holds 5.5 gallons."
He asked me if I just noticed low or if I had been checking the fluid. "Nope that's your guys job...was it checked the last time I serviced it..don't yall do a multi point inspection? Is coolant not a check point t in said inspection. "Supposed to be" was the response I got.
Ford's service is such shit for the money you pay for these trucks...unfortunately there aren't any better alternatives...
While I am on my soap box why is it almost 200 bucks cheaper to buy a new tailgate than 1 LED taillight.
1800 for a new taillight..
1600 for a new tailgate...
WTF..smh
WTF..smh
Long story, but something something warning labels.
WTF..smh
I would buy morimoto taillights 3x over before I buy one ford taillight (unless you happened to need the blis too.
WTF..smh
I don’t get the fascination with the factory LED lights. I can swap my XLT halogens to LED bulbs for pennies on the dollar to OEM LEDs.
Sincere question from another XLT halogen heads owner: Have you swapped to LED bulbs?
I ask because I believe there've been improvements to them, but I wouldn't know where to begin to sort through all the present day marketing hype.
If I could purchase LED bulbs w/ the appropriate left-hand-drive cutoff pattern low beams, AND in a 5000K color temperature, AND have them be RELIABLE, then I'll open my wallet.
Cheers!
Cheers!
I got them for my 23 Lariat since it didnt come with LED tails. They are very nice and easy to install. I liked that they are red LEDs, where stock is a clear bulb through a red lens. Red led makes them very bright red.
Cheers!
there's a lot of high performance LED bulbs for tails and turns; thou shall not run PnP led headlights though as that is a sin and blind everyone, do a proper retrofit or aftermarket headlamp conversion.
^ ^ ^ exactly, hence my 5000K color temp and proper low beam cutoff questions.
I wouldn't want to run any color temp higher than 5000 degrees Kelvin, and preferably w/ mid-level lumens' output.
I have to wait awhile anyway. It is only an exploratory question. Gonna be some roofin' goin on 'round these here parts next week and I've the garage to attend to before the crew gets here.
(and here I sit on FT.c lmao - but finishing an early lunch)
P.S. Still have those new in box Bilstein clamps!
For headlights : LED emitter w/projectors versus a LED bulb w/reflector is a HUGE difference.
For tail lights : Aftermarket replacement options are pretty good compared to buying OEM replacement. Best option is to be sure of the product quality before the price.
yea you want a retrofit (either HID or LED) I am still a big proponent, if you are not buying a set of aftermarket headlamps, of an HID retrofit as the way to go.
  1. one, they work better in cold climates and can self clean ice
    1. Downfall is brief warmup time.
  2. you get color options
  3. you get intensity / power
  4. you have replaceability/serviceability
  5. wider spread
For optimal night time anything technically over 4500k is losing lumens/output to color changes. The best performing set would be 50w ballasts driving a 5000k bulb as it increases the intensity and will burn at or close to 4500-4700.
For Corner or turn lamp bulbs, there's a ton of options from mild (replace frequently) to wild (will cost a pretty penny). If you have a colored lens you should always run the correct colored bulb, if not avail, clear. The reason being (such as a red tail lamps), the red plastic lens acts as a filter and removes all other light except the red spectrum (this is why they look dimmer) than if you ran a red LED bulb in a red lens housing.
I have blis. What's crazy is I knocked a quarter size hole in the taillight loading layout boats, decoys and whatnot in the dark..not sure what hit it..got buddy owns a wrecker company...I will get a better one eventually..still works fine.
It's has the standard red electical tape patch for now.
Cheers!
I have not. My son swapped his 2015 f150 bulbs and they are great. He got some off amazon do $125 or so.
