- Jun 25, 2020
- 6,468
- 10,967
- >>US Army<<
- Is she DAF or just ignoring me??
- 2022 F350 CCLB (11/2022)
- 2015 F350 CCLB 225k // 2006 F350 CCLB 280k
Are you running a lift or leveling kit??
100% OEMAre you running a lift or leveling kit??
Like when I rock my truck to get those damn bubbles out of my washer fluid reservoir so I can get almost the whole bottle in?..Seems most likely a failure to top off from recent work done. I'm not sure the 7.3L motors have any significant history of head gasket issues. I've see VERY LOW coolant levels from vehicles that have sat a fair amount of time. Even worse after work is done without proper topping off of fluids. I think it's that whole heat/coolant expansion thing that happens.
i do this for the reservoir too, i also do it to burp the S&B tank if I'm truly trying to squeeze it all in there for like a long trip or something.Like when I rock my truck to get those damn bubbles out of my washer fluid reservoir so I can get almost the whole bottle in?..![]()
i wonder if this is it right here, i know most trans shops require a new trans cooler for warranty purposes on all there performance transmissions, the cooling system on our trucks (at least the 6.7s i know yours is a 7.3) has a section off cooling loop for that purpose. I'd assume like all trucks since forever though the 7.3 has some sort of cooler and probably water to air cooler and not just an air to air cooler.Tranny was replaced and transfer case rebuilt at 60k so who knows what they took loose where.
My guess is you are getting residual burping since it sounds like they did not do a vacuum bleeder for a refill.
that's crazy, i dont know why more people don't use vacuum fillers, they avoid all of this lol and potentially keep components from failing. Not vacuum filling can leave deadhead spots too which weakens performance of things like your intercooler or heater core. On the Audi supercharged engines this is a big problem, creates hot spots in the intercooler bricks in the supercharger and they'll develop a leak, on top of that we call it the waterfall trickle where right behind the center dash radio you get what sounds like a "zen trickle" from one of those fountains; it'll drive you crazy lolThe heat exchanger on my truck for the Whipple took like 3 weeks to get all the bubbles out. I too thought I might have a leak but it finally stabilized.
I mean, I'm not a professional mechanic. I filled it, burped it, drove it, filled it, burped it... Its a constant on high flow pump, I thought I had it all, but after a week it was a touch low so I topped it off, a week later it was low again so I topped it off, seemed strange and I wondered if I had a leak. I check it now and it hasn't dropped at all so I think I am dialed.that's crazy, i dont know why more people don't use vacuum fillers, they avoid all of this lol and potentially keep components from failing. Not vacuum filling can leave deadhead spots too which weakens performance of things like your intercooler or heater core. On the Audi supercharged engines this is a big problem, creates hot spots in the intercooler bricks in the supercharger and they'll develop a leak, on top of that we call it the waterfall trickle where right behind the center dash radio you get what sounds like a "zen trickle" from one of those fountains; it'll drive you crazy lol
I'm not bagging on you bro, please don't take it that way, it happens. I've had to do enough coolant work over the years and ran into issues like dead head / airlocked heater cores in the past that I broke down and got one. One of those things kinda like a powerbleeder for brakes, do you need it no, does it help a lot, yes.I mean, I'm not a professional mechanic. I filled it, burped it, drove it, filled it, burped it... Its a constant on high flow pump, I thought I had it all, but after a week it was a touch low so I topped it off, a week later it was low again so I topped it off, seemed strange and I wondered if I had a leak. I check it now and it hasn't dropped at all so I think I am dialed.
I did buy one of those funnel things for the reservoir cap JUST for this project, and the damn thing didn't fit.
Oh no worries!! It would be nice to have one for sure. I slowly buy tools over time, Ill probably end up with one someday. I can't imagine how much I've saved over the years doing all of my own work.I'm not bagging on you bro, please don't take it that way, it happens. I've had to do enough coolant work over the years and ran into issues like dead head / airlocked heater cores in the past that I broke down and got one. One of those things kinda like a powerbleeder for brakes, do you need it no, does it help a lot, yes.
mine was purchased was born out of necessity after having the trickling waterfall noise that was driving me crazy lol. The first time you use one though you'll never go back.Oh no worries!! It would be nice to have one for sure. I slowly buy tools over time, Ill probably end up with one someday. I can't imagine how much I've saved over the years doing all of my own work.
actually, they arent even expensive lol
Amazon.com: Tomotato Coolant System Vacuum Purge Tool, Universal Radiator Refill Kit with Pressure Gauge and Flexible Hoses for Most Cars, SUVs and Light Trucks : Automotive
Buy Tomotato Coolant System Vacuum Purge Tool, Universal Radiator Refill Kit with Pressure Gauge and Flexible Hoses for Most Cars, SUVs and Light Trucks: Cooling & Water Pump Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Kind of wish I would have had a power bleeder for my bronco when I changed those damn brakes...I'm not bagging on you bro, please don't take it that way, it happens. I've had to do enough coolant work over the years and ran into issues like dead head / airlocked heater cores in the past that I broke down and got one. One of those things kinda like a powerbleeder for brakes, do you need it no, does it help a lot, yes.
I got a vacuum bleeder back when I used to race a lot and bled my brakes allllll the time.Kind of wish I would have had a power bleeder for my bronco when I changed those damn brakes...![]()
Rep said there is now way the system would still need burped...
Oh wow, I didnt realize it had been that long, sorry dude, good luck!Called and got an appt. Rep said there is now way the system would still need burped after 20k miles and a year..trany replaced last Jan at 65k, has 85k now. Taking in next Tuesday.
